RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   9CAF Trainer Function (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/3273994-9caf-trainer-function.html)
DaddySam 08-18-2005 02:15 AM
Hi
I'm teaching my son to fly and find that I have to check the trainer function every time. Sometimes it has stayed assigned but most of the time I have to go into the programming and enable it. Is this normal? I would have thought that the trainer function enabling would not change just because I've turned off the transmitter between flights.
Sam
Bayou Talker 08-18-2005 07:58 AM
RE: 9CAF Trainer Function
That seems to be a common thing with the 9C. It has been discussed quite a bit lately on other threads. Search for
"9C Flip Flop"
Krysta 08-18-2005 11:41 AM
Hi Sam,
No, this will always shut off when you turn your transmitter off, it is a built in safeguard in the transmitter. This is done so that if you were not training but just flying by yourself and you did not know it was enabled, and accidently hit the switch, you would lose control of your plane.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
ORIGINAL: DaddySam
Hi
Sam
