3pk display problem
Hi again
I just picked up a use 3pk and the guy didn't tell me it had the display problem Owell,, my bad fo buying used anyway,, I searched and saw others with the same problem Is is possible this is a recall item or will I have to pay to have it fixed? If so how much about will it cost? Th radio works fine just the screen cuts out every once in a while, So far still completely useable. I just need to reboot to get the screen back By the way,,, I had a similar problem with a Hitec radio and they fixed it FOC any chance Futaba will step up? |
RE: 3pk display problem
Futaba warranties items purchased by the original owner. As you purchased this used, no, it would not be covered under warranty.
Also there is not a "recall" on the 3PK as this is not a recurrent problem with these. The costs of replacing the LCD display would be approximately $70.00 including labor and shipping. I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721. Sincerely, Krysta Lead Futaba Customer Service and Programming Technician ORIGINAL: had enough Hi again I just picked up a use 3pk and the guy didn't tell me it had the display problem Owell,, my bad fo buying used anyway,, I searched and saw others with the same problem Is is possible this is a recall item or will I have to pay to have it fixed? If so how much about will it cost? Th radio works fine just the screen cuts out every once in a while, So far still completely useable. I just need to reboot to get the screen back By the way,,, I had a similar problem with a Hitec radio and they fixed it FOC any chance Futaba will step up? |
Krysta,
Never hurts to ask, right? $70 is very reasonable. Thanks for the info,,, I'll send it in once the race season ends Futaba Rocks!!! |
| All times are GMT -8. The time now is 04:41 PM. |
