RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   Futaba Synchronizer (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/433876-futaba-synchronizer.html)
didiwatt 12-23-2002 12:52 AM
Futaba Synchronizer
Anne Marie:
I am new to 1/3 scale and am working on an Edge. I use a 9ZWC2. I plan on running 2 - 9206 servo's per aileron and have never done this before. I plan on using the new Futaba Snychronizer. In reading the information, IT says you can run up to 4 servos per unit. Am I correct in assuming that this is per channel. In other words, I would need one snychronizer for each aileron, correct?
Thank You
Paul
amcross 12-23-2002 10:35 PM
Futaba Synchronizer
Paul,
IF you need to have aileron differential or flaperons, then yes you would need 2, one for each aileron. If you can run all 4 servos to one channel without losing any setup flexibility, all 4 can be run into a single synchronizer, no problem.
