RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   9CAP-ELEVATOR PROBLEMS (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/4444263-9cap-elevator-problems.html)
flyerdave 06-29-2006 08:51 AM
I HAVE A 9CAP WITH PCM RECEIVER IN A GOLDBERG EXTRA 300. HAD NOT FLOWN THIS MODEL IN 6 MONTHS AND THE OTHER DAY WHEN I WENT TO FLY, I TURNED ON THE RADIO, THEN THE RECEIVER AND DOING A CHECK, FOUND THAT WHEN I PULLED UP ELEVATOR,LEFT HALF GOES UP, RIGHT HALF GOES DOWN. I CANNOT FIGURE OUT WHAT I MAY HAVE DONE TO CAUSE THIS. OBVIOUSLY, THE ELEVATOR HALVES ARE CONTROLLED BY SEPERATE SERVOS ON A Y- WIRE. I HAVE CHECKED ALL THE MIXING SWITCHES WITH NO LUCK. tHANKS FOR THE HELP.
Bax 06-29-2006 02:53 PM
RE: 9CAP-ELEVATOR PROBLEMS
Normally, when two servos are put onto a "Y" connector, mounted as elevator servos, and then have identical connections, the two elevator halves WILL work opposite to each other. You'd need a reversing "Y" connector to get them to operate in the right directions.
Also...if the two elevator servos are operating off of a "Y" connector, they would not use any mixing in their function. You'd have the servos connected to separate channels and then use the ailevator function.
flyerdave 07-01-2006 09:25 AM
well, I have egg on my face. I did not have the elevator servos on a Y-wire but instead had channel 2 and 8 mixed with 8 being the slave. got it all figured out last night and I can't wait to get my extra 300 back in the air. Thanks
