RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   delay function T8UPS (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/4579657-delay-function-t8ups.html)
w.pasman 08-03-2006 03:24 PM
Bax
Could you please explain this on the Futaba T8UPS
The manual says "The Delay function is automatically activated when either
Offset, Revolution mixing, or Throttle hold are activated."
Now if I look in the Delay menu, I see AIL off, ELE off but RUD on. All values are 0.
I want no delays anywhere and would like to see them all either OFF or even better inhibited.
I can change the values but that does not change anything between on and off.
Nothing happens with the delay (stays off,off,on) when I flick the idleup or hold switch.
All OFFSTiv, OFFST-1 and OFFST-2 are inhibited
Invert, and all revo mixing are inhibited as well.
Bax 08-04-2006 03:11 PM
RE: delay function T8UPS
You can't control when delay is on or off. That's set in the transmitter. Its purpose is to smooth the difference between the trim of the different functions. If you want no delay, leave it set to 0. Then ignore it.
