9C Super Flaperon Question
Can the flaperon function be assigned to a switch rather than a dial? I would prefer just simple on off for this feature. I have the 6EXAP right now and cannot get it done on this radio, but will upgrade if the 9C can do it.
Thanks Bob |
RE: 9C Super Flaperon Question
Hi Bob,
Unfortunately, no, as per our FAQ: http://www.futaba-rc.com/faq/faq-9c-q524.html I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721. Sincerely, Krysta Hunt Lead Futaba Customer Service and Programming Technician Futaba Service Center USA ORIGINAL: wildchild45177 Can the flaperon function be assigned to a switch rather than a dial? I would prefer just simple on off for this feature. I have the 6EXAP right now and cannot get it done on this radio, but will upgrade if the 9C can do it. Thanks Bob |
Krysta sorry to butt my way in but this is an easy mix. You can use an aux knob for the master and flap for slave on one side. Then the aux knob master and aile for slave on the other. Onse the %'s are set you can pick a switch.
I hope I did not step on your toes Krysta. You are a help to all of us and have helped me in the past. Have a great day,David |
| All times are GMT -8. The time now is 07:25 AM. |
