RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   Transmitting problem (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/4627401-transmitting-problem.html)
shmikeuk 08-15-2006 07:10 PM
hi there, i just have a quick prolem to anyone who can help.
I have a piper cub that i have purchased second hand.. and it seems to be in good condition. however, when i turn on my transmitter and the reciever, the plane controals only work when im within a 2 meter radius of the plane. any further then this and nothing.
is this a power problem (my transmitter battery is putting out the propper voltage) or is there somthing else i may have missed.
any help is greatly appreciated
mik :D
shmikeuk 08-16-2006 01:25 PM
RE: Transmitting problem
oh yeh, im using an 8 channel GWS reciever with futaba servos and a skysport 6 transmitter.
Bax 08-16-2006 04:51 PM
If you get proper range with a Futaba receiver when you use your Futaba transmitter, then you'll need to check to see what may be wrong with your receiver. Remove the equipment from the airplane and do a range check with the receiver supported above the ground with the receiver antenna extended vertially (don't use a metal support). See what range you get then.
No way for us to tell you what may actually be wrong. If you get normal range with a Futaba receiver, then it's not your transmitter. If you don't, then your transmitter may require service or repair.
