Dual rudder in 12MZ
I have two servos for Ailerons,(no problem) two for elevator (ailevators) , and need connect two for rudder.
How connect two servos for rudder in my Extra 330 ? Thanks Spynete |
RE: Dual rudder in 12MZ
Hi Spynete,
All you will need to do is to go into your Function menu and scroll until you see a spare channel that you are not using on your receiver that you would like your second Rudder to be. Once you are there, lets say channel 6 Gear is free. With this highlighted when you push the Data wheel done you will be at the Function selection screen. Now you will just scroll until you see the words Rudder2. Once more press the Data wheel and you will have selected this channel to be your second Rudder servo. You will now need to toggle over and select the control lever that you want this associated with. You will use the joystick that the rudder is currently on, such as J2, or here in the US J2. Toggle over once more and you will need to set the Trim for this second Rudder. I hope you find this information helpful. You can also reach our Futaba support team at 217-398-8970 opt 2, or via fax at 217-398-7721. Sincerely, Krysta Hunt Product Development & Support Specialist Futaba Service Center USA ORIGINAL: Spynete I have two servos for Ailerons,(no problem) two for elevator (ailevators) , and need connect two for rudder. How connect two servos for rudder in my Extra 330 ? Thanks Spynete |
Krysta
Ive run into a problem with the D/R on the rudder2. I asume that because there are only 3 tail types and 2 rudders isnt one that I must have dual rates for each rudder, and wonder if this is the only way to fix this issue? |
Why can't you just use the rudder function twice? For example channel 7 be rudder and channel 8 be rudder.
