Multi servo control surfaces
I have my first large scale gas aerobatic plane, this is cause for some questions regarding control surface set up. It calls for two servos on each surface, 2 ail, 2 elev, and 2 rudder. What are my options for making sure the servos are matched and so on. I want it set up correctly.
RE: Multi servo control surfaces
Sorry Bax and Krysta for posting,,,delete if you need to...
Devin, which radio? if it is the 12 or 14z then simple use a seperate channel for each servo and set up end points and throw for each one I use a 9C on a similar set-up and I use the MAS-10 from Futaba. Works perfectly for matching servos together...... |
Hi Devin136,
Most large scale gas planes with multiple servos per surface would use a matchbox or synchronizer such as our FUTM4155, which makes matching end point and travel very simple and precise. This extra weight and connection would not be necessary if using a 12Z or 14MZ as you would be able to make these adjustments in the programming. I hope you find this information helpful. You can also reach our Futaba support team at 217-398-8970 opt 2, or via fax at 217-398-7721. Sincerely, Krysta Hunt Product Development & Support Specialist Futaba Service Center USA ORIGINAL: devin136 I have my first large scale gas aerobatic plane, this is cause for some questions regarding control surface set up. It calls for two servos on each surface, 2 ail, 2 elev, and 2 rudder. What are my options for making sure the servos are matched and so on. I want it set up correctly. |
| All times are GMT -8. The time now is 09:13 AM. |
