RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   TX RX compatability (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/5087212-tx-rx-compatability.html)
madolive3 12-07-2006 03:16 PM
TX RX compatability
Will different brands work together? If on the same band and channel will my Airtronics RX work with a new 9cap?...thanks..
sqwally 12-08-2006 02:08 PM
RE: TX RX compatability
Most manufacturers(including Futaba)does not recommend the use of other manufacturers merchandise with their products.
Airtronics is on a different shift than Futaba.
Airtronics and JR are positive shift while Futaba and Hi-Tec use negative shift.
So in short,no, your receiver would not work with the Futaba transmitter.
Bax 12-11-2006 04:36 PM
While a number of non-Futaba receivers will work with Futaba transmitters, we'd by no means have a list. We do know that Airtronics FM equipment is not compatible with Futaba equipment, so your Airtronics receiver will not work with your Futaba 9C transmitter.
