RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   14 MZ Elevon setup (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/5370490-14-mz-elevon-setup.html)
Mitchell-RCU 02-04-2007 04:09 PM
14 MZ Elevon setup
How do i set up elevons on the 14MZ. I have a Hotspot and have not been able to set it up correctly.
MItchell
Bax 02-05-2007 11:52 AM
RE: 14 MZ Elevon setup
You will need to change the wing type to "Flying Wing" of the correct configuration. You will set up two aileron servos, and the elevator function will be on a virtual channel and operate normally.
Mitchell-RCU 02-06-2007 04:29 PM
Thats what i did. I then went to ail differential and tried to set the control throws. The left aileron(aileron 1) sets fine. When i set aileron 2 to the same value i still get full deflection. The virtual elevator seems to work fine except it needed to be reversed. I did that with the H/W reverse.
Mitchell
