9 CAP and flaps using the VR(E)
Hi. I've got a 9 CAP and am using a 8 channel PPM Rx.
I have a project using twin aileron servos (on ch 1 and 6) and would like to have them operate as flaps using the VR(E). I've got the ailerons mixed using the flaperon function, but when I go to set up the flaps, the VR(E) isn't a choice. How else can I do this? Thanks |
RE: 9 CAP and flaps using the VR(E)
Hi Dave,
This is very simple to do with the 9C. Simply go into an empty Pmix, set the Master as VR-E, and the Slave as Aileron, next sent the Link ON, leave the switch Null, and set the rate at +100%. This should get you what you want. I hope you find this information helpful. You can also reach our Futaba support team at 217-398-8970 opt 2, or via fax at 217-398-7721. Sincerely, Krysta Hunt Product Development & Support Specialist Futaba Service Center USA ORIGINAL: Dave G Hi. I've got a 9 CAP and am using a 8 channel PPM Rx. I have a project using twin aileron servos (on ch 1 and 6) and would like to have them operate as flaps using the VR(E). I've got the ailerons mixed using the flaperon function, but when I go to set up the flaps, the VR(E) isn't a choice. How else can I do this? Thanks |
| All times are GMT -8. The time now is 11:29 AM. |
