6EX fasst buddy box setup
I bought 2 6ex 2.4GHz FASST boxes for my 2 kids. I also got the connector cable for the transmitter. When I hook the cable up and switch the master on (with the slave off), I am not able to control the plane with the slave box at all, no matter in what position I hold the trainer switch on the master box. Master always controls the plane. The slave box is "lit" up, but the control input has no consequence on the palne. What am I missing???
Any help is greatly appreciated. Thanks, Andreas |
RE: 6EX fasst buddy box setup
Did you turn on the Trainer function in the transmitter you want to use as the master? Please see page 15 in the manual.
Hi Bill,
thanks for this very valuable piece of information. That is exactly what happened. Maybe you could indert that info also on pg. 33 of the manual. I looked in the index for the buddy box set up and it referred me to pg 33, and there is no mention of that. Great and fast advice, I appreciate your quick help. With best regards, Andreas ;) |
<font style="color: rgb(42, 42, 42); font-size: 12pt; " face="'Courier New'" size="3">
I have the FUTABA FASST T7c for more than a year and it is the best radio I ever had but....<b style="line-height: 20px; font-weight: bold; "><span style="color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); " class="ecxhps">I just found</span><span style="color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); "> </span><span style="color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); " class="ecxhps">my first problem, the trainer program will not activate I have done every thing </span>[/b] that the<span style="line-height: 20px; color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); " class="ecxhps"> instructions</span><span style="line-height: 20px; color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); "> </span><span style="line-height: 20px; color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); " class="ecxhps">in the book say, so I'm not sure if I'm missing </span> <span style="line-height: 20px; color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); " class="ecxhps">a menu or</span><span style="line-height: 20px; color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); "> </span><span style="line-height: 20px; color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); " class="ecxhps">am I doing</span><span style="line-height: 20px; color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); "> </span><span style="line-height: 20px; color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); " class="ecxhps">something wrong? (the snap roll works just fine so the switch isn't broken)</span></font><div style="line-height: 17px; color: rgb(42, 42, 42); font-family: Tahoma, Verdana, Arial, sans-serif; font-size: 13px; "><font style="line-height: normal; font-size: 12pt; " face="'Courier New'" size="3"><span style="line-height: 20px; color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); " class="ecxhps">I have the training cord that match both radios(it came with the Real Fight G5.5) I'm trying to use the Futaba SKYSPORT T4YF (FM) as the training box </span></font></div><div style="line-height: 17px; color: rgb(42, 42, 42); font-family: Tahoma, Verdana, Arial, sans-serif; font-size: 13px; "><font style="line-height: normal; font-size: 12pt; " face="'Courier New'" size="3"><span style="line-height: 20px; color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); " class="ecxhps"> </span></font></div><div style="line-height: 17px; color: rgb(42, 42, 42); font-family: Tahoma, Verdana, Arial, sans-serif; font-size: 13px; "><font style="line-height: normal; font-size: 12pt; " face="'Courier New'" size="3"><span style="line-height: 20px; color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); " class="ecxhps">check this video were I show the problem (I hope I'm just doing some thing wrong)</span></font></div><div style="line-height: 17px; color: rgb(42, 42, 42); font-family: Tahoma, Verdana, Arial, sans-serif; font-size: 13px; "><font style="line-height: normal; font-size: 12pt; " face="'Courier New'" size="3"><span style="line-height: 20px; color: rgb(51, 51, 51); background-color: rgb(245, 245, 245); " class="ecxhps"> </span></font></div><div style="line-height: 17px; color: rgb(42, 42, 42); font-family: Tahoma, Verdana, Arial, sans-serif; font-size: 13px; ">http://www.youtube.com/watch?v=DhLmzFI7jDQ</div><div style="line-height: 17px; color: rgb(42, 42, 42); font-family: Tahoma, Verdana, Arial, sans-serif; font-size: 13px; "> </div><div style="line-height: 17px; color: rgb(42, 42, 42); font-family: Tahoma, Verdana, Arial, sans-serif; font-size: 13px; ">I hope you can help me </div> |
Watched the video, maybe you should try an actual set-up with the two Tx connected by a trainer cord and a master Rx and servos to verify the function. It might be that the trainer function in the 7c only enable when connection is established..
http://manuals.hobbico.com/fut/7c-2_4ghz-manual.pdf http://manuals.hobbico.com/fut/4yf-manual.pdf |
thanks for replying
that was the first thing I try just like the book says and I thing is just like you say, the buddy box have to be connected for the trainer program to activated butstill doesn't work so Itry it the other way around using the SKYSPORT T4YF as the master and the T7C as buddy box and when everithing is connected the SKYSPORT control the servos just fine but when i hit the trainer switch the servos stop responding to de controls (like it shuold be) but the T7C does no control them either so I think there may be some thing wrong with the T7C trainer connection hole or output |
