RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   Need to set up a throttle/elevator mix on the 9Z (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/6588157-need-set-up-throttle-elevator-mix-9z.html)
Aerobat 11-06-2007 11:46 AM
I just picked up a nearly new Futaba 9Z WC2 and I'm using it to fly aerobatic planes with ailerons on 1 and 7, elevators on 2 and 5. I've read the manual and FAQs and have most everything figued out. But I'm stumped on how to set up a mix that will give me a touch of down elevator when the throttle is closed.
I set up an offset mix, but it's going backward - I get elevator movement when the throttle is in any position EXCEPT closed. Any tips would be appreciated.
Mark
Aerobat 11-07-2007 08:53 PM
RE: Need to set up a throttle/elevator mix on the 9Z
From the lack of response, I assume it isn't possible to do the throttle/elevator mix - that's strange, given that it's easy to do on my trusty old 8U.
BrunoCH 11-09-2007 07:06 PM
This is the way I do it on the Zap WC1:
After setting the mix, I program the throttle stick to be the on/off switch for mix. To do this, go to the Pmix screen and select SWT and STK. Select your throttle stick (usually J3), put the throttle where you want the mix to be activated and press SET. Make sure that, on the graph, ACTIVE is on the bottom of the travel, if not use the +/- key. It should work now.
charrua 11-10-2007 09:19 PM
Mark what would be the point of having down Elevator when the Throttle is closed,,if you dont mind me asking???
Aerobat 11-10-2007 10:16 PM
A lot of guys do it, it keeps the plane from pulling out of downlines. Someone PMd me with the proper setup.
charrua 11-11-2007 09:16 AM
ORIGINAL: Aerobat
So how do you start the engine back again if you have your throttle close on downline?????
I guess what you ment then is how do you give down ele. to idle throttle position right!!!
