RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   9c problem (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/7864771-9c-problem.html)
gcgabelm 08-19-2008 09:30 PM
9c problem
Has anyone had a futaba 9c radio that when you turn it off then turn it back on and it gives the two beeps for booting up but it does not transmit and it has to be turned off pull the campac out put it back in turn the power on and then it boots and starts transmitting like normal until it gets turned off.
sigflyer1 08-19-2008 09:40 PM
RE: 9c problem
Hay I was going to buy one,But the way you talked about it.
I don't think I will.
But I Hope You'll Get YOURS Fixed.
Dan767 08-19-2008 11:43 PM
RE: 9c problem
Four years of flawless performance with mine.
nedyob 08-20-2008 06:31 AM
RE: 9c problem
Never had a problem like that in the 6 years I've owned my 9C, Might want to check with Hobby Services and get the radio checked out.
NEDYOB
Bax 08-22-2008 10:10 AM
RE: 9c problem
It sounds like your transmitter has something wrong inside. It needs a trip to the service center to be checked out. Could be a hardware OR software problem.
