Software Uptdate for 14MZ and FX-40 Transmitters
Futaba has just released an update for the 14MZ and the FX 40. This
software update contains several very important updates for your T14MZ transmitter. Futaba Model Data Converter- We now have a tool to allow you to convert model data between the 12FG and the 12Z and 14MZ! This application is very easy to use and works well. Both the update and the file converter are available at: http://www.futaba-rc.com/sellsheets/index.html Power-Down Refinement: TM-14 Transmitter Module- When using the TM-14 FASST transmitter module in the power-down mode, this update will provide you with an additional visual indicator to ensure that you do not attempt to take-off while the RF output is in the weakened (range check) state. Previously the LED in the Futaba logo at the top of the transmitter would remain solid green, thus indicating the typical RF output. The LED now blinks, or flashes, when it is in the powered-down mode providing you with another safety indicator to ensure that you enjoy your modeling experience. Futaba Model Data Converter- To support the Futaba Model Data Converter, it is necessary to update the T14MZ to version 1.3.2. After the update is applied to the transmitter, the model memory will automatically update the necessary data files in order to be useable with the Futaba Model Data Converter. As a reference, the Futaba Model Data Converter is designed to allow modelers to quickly and efficiently share data between various Futaba transmitters that utilize either an SD or CF memory card. For example, it is now possible to copy the model data from a T14MZ transmitter and utilize this data on Futaba's T12FG system without having to manually reprogram the 12FG to do so. |
