T8UAF reciever compatability?
I have a T8UAF on channel 33. It will work with a Futaba FP-R148DF reciever, but not a Futaba R168DF reciever. Is there a reason for this? Thanks!
RE: T8UAF reciever compatability?
it should work, just be sure the radio is in ppm mode
Both receivers are PPM receivers. Please make sure the crystals in the inoperative receiver is fully-seated in its slot. Also please make sure it's a dual-conversion crystal, and on the same channel as the transmitter. You may want to try the crystal in the R148DF receiver in the R1618DF receiver to see if the crystal is the problem.
