8U Super HELP
Hi,
I have an 8U Super which I am trying to program for 2 aileron servos on the ACRO mode. The only way I can get it to recognize the second servo is in the GLID2FLP mode. When I switch over to ACRO mode I lose the second servo. Am I missing something ? Thanks ! jef :confused: |
8U Super HELP
Hi Jef,
Do you have the two servos in channels 1 and 6? If you do then using Flaperon in Acro mode will be what you want. If you have your servos in channels 1 and 7, then you will want to use Aileron Diff. I hope you find this information helpful. Should you have any further questions or concerns, please do not hesitate to contact us at 217-398-8970 for Support, 217-398-0007 for Service or via fax at 217-398-7721 or by email at [email protected]. Sincerely, Krysta Lead Futaba Customer Service and Programming Technician Also you may want to check our Website at (http://www.futaba-rc.com) |
Thanks, Krysta
Thanks for the quick response, your help as always is greatly appreciated.
jef :D |
8U Super HELP
You're welcome Jef,
Have a good day, Krysta |
| All times are GMT -8. The time now is 12:05 AM. |
