PPM to PCM interference
Can a PPM transmitter on the same channel as a PCM transmitter cause the PCM plane to crash? PCM is NOT in failsafe mode.
We have conducted some tests which showed PPM did not affect PCM, but last week a PCM system took off on my channel (I was posted and legal). My PPM plane being preflighted in the pits was acting strange. I finally pulled out my antenna full length and at that time the PCM plane over the end of the runway fatally crashed. No controversy over whose fault, he admitted it. If I had taken off first, he would have shot me down and owed me a plane. We have a confirmed PCM flyer who claims when on PCM, a PPM signal will not cause him to crash. The above episode tends to prove him false. Who is correct? Coop |
Any time a receiver gets signals on its channel from two different sources, you have a problem. If you are flying a model in PCM mode, and someone else turns on a PPM transmitter on the same channel, your PCM receiver should go into lockout or failsafe, depending upon how it's set.
If the offending transmitter is on long enough, the model in the air will crash. Only if the model could continue to fly, like a free-flight model, with the PCM transmitter actually turned off, could you say that the model woudn't crash. We're sorry, but two or more transmitters on the same channel, operating at the same time, will effectively make that channel unusable for ANY flier, no matter what kind of coding they happen to be using. |
| All times are GMT -8. The time now is 07:38 AM. |
