RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   12 FG Fasst - programming an optical kill switch (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/8828621-12-fg-fasst-programming-optical-kill-switch.html)
georgebonn 06-05-2009 05:12 PM
I cannot figure out how to assignchannel 9to switch HS to operate an optical ignition kill switch. What is the procedure ??
Thanks........George Bonn</p>
Bax 06-08-2009 12:12 PM
RE: 12 FG Fasst - programming an optical kill switch
You would go into the Linkage Menu and then the Function section. Assign the desired switch to channel 9. Rename the function in the "Function Name" section of the Linkage Menu. Then go into the Model Menu and the "AFR" section. You can adjust the throttle cut function's AFR there.
Please realize that your original post was after business hours on Friday. Of course we'd not be able to answer until today.
