MSA-10 programming question
I am having a problem with my MSA-10 that I know is my fault but I do not know what to do about it. Ihave two servos hooked up into the unit and absolutly nothing is happening. I know this is not the unit because both the MSA-10's that I have are both doing nothing. The red light is on and everything. The question is this...I do I get this to work. I have had no problems previously with these units but for some reason I cannot figuer out what I am doing wrong to get these servos to move. I have read the manual for them and I just cannot seem to get this working. I have set it to 0 and 9 to see what happens and the servos still do not move. I have even tried resetting the unit and still I cannot seem to figuer out what I am doing wrong. Tell me what I must do in order to get this to work
Thanks Chris |
RE: MSA-10 programming question
The first thing Iwould check is to make sure that the battery input connector is properly inserted. The only time you will not use this is if you are powering the servos connected to the MSA-10 by a separate battery. Otherwise this must be plugged in.
Sincerely, Krysta Product Development & Support Specialist Futaba Service Center USA [email protected] |
All that I am going to say is that I deserve the Darwin award for this one. I plugged the battery input connector in and its working. Thanks for everything.
Hahaha, no problem, glad it was an easy fix!!
Take care, Krysta |
| All times are GMT -8. The time now is 08:35 PM. |
