RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   new 7C Programming questions (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/9807746-new-7c-programming-questions.html)
cloud_master 06-16-2010 07:21 PM
Hello. I have a question on my new 7C. I would like to use the flaperon mixing for independant aileron servos, 1 and 6. I also have a servo per elevator half. I'd like to also use the Alevator function. Can I do this with the 7C, or is the 8 channel required for this? Or do I need to use the reversing y harness for my elevator servos? It looks like according to the book, that I can either do independant aileron servos, or independant elevator servos, but not both. Just wanted to hear it from the people in the know. Thanks.
Bax 06-23-2010 01:43 PM
RE: new 7C Programming questions
If you have the 7C FASST transmitter, you can do both. You use the Flaperon function for dual aileron servos, and the Ailevator function for dual elevator servos.
If you have a 7C transmitter on the 72 MHz band, it has the Flaperon function only. To get dual elevators, you use a p-mix, but you won't have trim on the slaved channel.
