Programming shutter release in Pmix on a T8UAF
Hello, I'v got an old Futaba T8UAF which I really like. Some don't like the complicated nature of it and I guess thats why I am here.
I'm using channel 8 on switch F to trigger a "Prism" module from Hexpert Systems. That trainer switch only has one rate direction so the module is not programming. It looks like I need two directions and a center to program the Prism. Channel 8 to Channel 8, 100%+ and 100%+, no link, looks like slave is on (can't switch that) switch f If anyone could lend some info I would greatly appreciate it, thanks! |
RE: Programming shutter release in Pmix on a T8UAF
Unfortunately, you will not be able to do this if you are using switch F, is there another switch you could assign this to?
Sincerely, Krysta Product Development & Support Specialist Futaba Service Center USA [email protected] |
I guess switch "c", its a 3 position switch. Is there one you would recommend using? Programming instructions? Thanks so much!
Any open 3 position switch that you are not using would be fine.
Am I correct that you want the Center position to be more or less empty, or that it leaves the switch neutral? If so, then I would have you do two Offset Pmixes in your radio, assigned to the switch in the Down position and the Up position. An Example: Pmix 1 Set INH to Off or On Set the Master as Offset Set the Slave as CH8 Cursor Right and set the rate to +100% Cursor Right leave the Link off Cursor right set the Switch to C in the Up position. Now go to the next Pmix and do the same exact thing, but set the Switch to C Down. This will leave the Center of the switch free but allow you to set the Zoom with one direction of the switch and the shutter with the opposite direction. Sincerely, Krysta Product Development & Support Specialist Futaba Service Center USA [email protected] |
| All times are GMT -8. The time now is 11:55 PM. |
