RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   slave to master (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/9929104-slave-master.html)
BobH 08-12-2010 02:56 PM
slave to master
Bax. whats a simple way to slave a servo to the retract switch on the 14mzh. I have a nose gear servo that is reverse from the main gear servo's (replacement ones on an EDF jet). So I'm putting the nose gear servo on channel 7 and want to slave it to the other two.
Thank You in advance,
fyi I've misplaced the 14mzh manuel..duh me
BobH 08-12-2010 03:08 PM
RE: slave to master
Sorry, I figured it out already using the function menu.
