Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 What Aircraft are you installing your DLE20 >
Old 01-17-2011, 08:08 AM
  #301
Default RE: What Aircraft are you installing your DLE20
I've never owned a gasser, but with the price of glow fuel, I'm ready to start. I just need some help to decide if the DLE 20 is right for my airplane.
I have a NIB Great Planes PT-19 ARF.
Wingspan is 82.5 inches
Area is 1027 sq in
Weight is 9.75-10.5 lb.
Box says 2 stroke 61-91, 4 stroke 91-1.20
I have an old review which says it flew great on an O.S. 91 4 stroke.
Do you think the DLE 20 is too much for this aircraft?
ED
Old 01-17-2011, 08:17 AM
  #302
My Feedback: (14)
jstanton's Avatar
Did a another test run of the DLE-20 again and I am only getting 7800RPM with a MAS 16x8 prop. I workrd on the high and low end setting but the RPM's never went any higher. I think my tach my be off. The engine sounds like it is turned OK so I am thinking that is the problem. I will go fly the PT-17 and work on the needles some more. I rotated the carb and installed the JTEC pitts muffler, now I cannot get to the needles unless I remove the cowl and pitts muffler[:'(] I will work on it any way. I think I will finish the plane this week and then take the cowl & pitts muffler off and then install the stock muffler and get the engine turned right Here is a video of how it is running for now. It sounds really good.
http://www.youtube.com/watch?v=OjQMqUJUpA0
Old 01-17-2011, 08:20 AM
  #303
mschulz531's Avatar
Jim S. has been posting on this very forum about that very plane, I think. Look back one or two pages and you will find a bunch of info and pictures. I agree - the cost of glow fuel has me moving to gassers as well.
ORIGINAL: Gypsy56
Area is 1027 sq in
ED
Old 01-17-2011, 09:24 AM
  #304
My Feedback: (7)
a1pcfixer's Avatar
ORIGINAL: Gypsy56
Area is 1027 sq in
ED
Should be a great combo, and have plenty of power for that model!
Bottom of this first post/msg, I had created a listing/index of sorts on the DLE20cc gas eng;
http://www.rcuniverse.com/forum/fb.asp?m=9863953
Old 01-17-2011, 09:33 AM
  #305
My Feedback: (7)
a1pcfixer's Avatar
Jim,
Temp, humididy, alt, etc all play a part in it. I'd say it sounds great, and if transistion is good....go fly it!!!
Btw; you need to give Gypsy56 some pointers. He just posted, inquiring about your very same model.
Old 01-17-2011, 09:57 AM
  #306
Perhaps you start adding to the list of all the planes that have flown with the DLE-20?
Old 01-17-2011, 11:08 AM
  #307
My Feedback: (8)
D_wilbur's Avatar
I bought 4 DLE 20's for my Don Smith B-29 enlarged plans. Started building it this week end. [8D] I hope to have it built in 2 years. Cheers
Old 01-17-2011, 01:31 PM
  #308
My Feedback: (7)
a1pcfixer's Avatar
ORIGINAL: ghoffman
What, and have those "search challenged" + newbies crying because they can't/won't look for such a list?
Be my guest if you'd like to compile such, but I've BTDT, no thanks.
Old 01-17-2011, 03:55 PM
  #309
Hmmm... You people are giving me an appetite.
I have a Senior Telemaster with a Webra 120 (which I will be maindening on Wednesday). It is a BIT overpowered, so switching to a DLE20 would be a beneficial move. Ground clearance on a Telemaster is a trivial matter :-).
The question is where to buy (reasonable shipping) a DLE20 over here....
M
Old 01-17-2011, 04:11 PM
  #310
My Feedback: (7)
a1pcfixer's Avatar
ORIGINAL: mixerfix
Hmmm... You people are giving me an appetite...........The question is where to buy (reasonable shipping) a DLE20 over here....
The best place & only one I'd buy them from is Valley View RC (USA)....
http://www.valleyviewrc.com/DLE-20cc%20Gas%20Engine.htm
Maybe you can get one shipped to you from them, or see if another dealer is closer for you.
DLE factory authorized dealers listing.....
http://www.dlpower.net/custom.asp?id=7
Old 01-17-2011, 04:19 PM
  #311
jedijody's Avatar
We ship world wide and have other customers in Israel also.
Old 01-17-2011, 05:00 PM
  #312
Maxford n28
Old 01-17-2011, 06:29 PM
  #313
My Feedback: (278)
my dle 20cc is going in a bh hobbies T-28 it will be truning a 3 bladed 14x9prop
Old 01-17-2011, 06:51 PM
  #314
My Feedback: (14)
jstanton's Avatar
Gregg,
I am having trouble sending you a pm. I just want you to know that if you rotated the carb 180 degrees like we talked about you need to test run the DLE-20 before you install the pitts muffler. If you don't you will not be able to adjust the low & high end needles. I am going to have to take off the pitts muffler to get to the needles because I am onyly getting 7800RPM with a MAS 16x8 prop. I have been told I should be gettign close to 9000RPM with that prop. I know the PT-17 will fly very well at 7800RPM but I like to have all the power I can get out of an engine so I'll try and adjust the needles Good luck on yours I see you are coming along very well with the DLE-20 install
Old 01-17-2011, 07:18 PM
  #315
I am installing the DLE 20 in a Ohio Model Products Profile Yak. I had an O.S. 120 FS in it . It flew well , very powerful and easy to fly. With low control throws you train some one to fly on it.
Very durable and easy to maintain .
I am expecting the DLE 20 to be almost as good - but not better . It is quite a bit heavier and I am not sure it has as much power . But we shall see.
The mounting is complete and it was really easy . The engine just dropped right in . If I could have moved it back I would have but ther was just no room with rear position of the carb.
I am using a Tec Arrow I BEC. It will use the same huge battery as my Rx and this save some weight by not requiring an additional battery for the ignition.
I am happy to answer any question anyone may have .
Allan
Old 01-18-2011, 01:51 AM
  #316
Thanks Jim,
You'll get a little less with the Pitts I woulds think..but not that much. I will be ordering the smaller Pitts to help clear the dubro mounts and hope to have enough room to get to the needle with the mount and smaller pitts. We shall see.
Old 01-18-2011, 07:11 AM
  #317
WHo makes the 14x9 3 blade yuor going to use. I ,ay need some grpund clearance.
Thanks. ML
Old 01-18-2011, 08:49 AM
  #318
I assume this is the Razor Yak? I have one nib and will be putting a DLE-20 on it as well (as soon as funds permit another DLE-20). Please post pics of your setup! I am very interested how you did yours!
Thanks, Gary
ORIGINAL: allans
Allan
Old 01-18-2011, 09:22 AM
  #319
Hi Vinmech,
Just a thought on your high speed missing problem. Check the size and condition of your ignition battery(s). The higher the RPM, the higher the amperage. If you are using one battery for your ignition and receiver, you could be putting yourself in a position to lose control of your aircraft. If the ignition is pulling the voltage down from the battery and you are using the same battery for your receiver, the receiver may momentarily shut down and try to reboot if the voltage gets low enough. This is especially true for the 2.4 ghz. radios as they seem to be more sensitive to the shut downs. It takes them longer to reboot than the older 72 mhz radios. While it is trying to reboot, 2 or 3 to 8 seconds, bad things can happen to your airplane. And your wallet. Hope that solves the high speed missing.
Steve
Old 01-18-2011, 10:54 AM
  #320
I don't think it is a Razor. I don't remember that being called that . Just a regular OMP Profile Yak.
I just checked the OMP websites . Mine is not the Razor. Mine is larger - the wing span is about 80 inches and a 120 size aircraft.
Will post how this comes out - right now it looks heavy and I don't see how it can equal the power of my OS 120 FS.
But we shall see.
Old 01-18-2011, 11:20 AM
  #321
Well, I would like to see it in any case, please. I don't know how a OS 120FS compares to an OS 120AX, but the DLE-20 is very close to the 120AX. I have had both on the same plane.
Old 01-18-2011, 12:00 PM
  #322
I have an 120 AX and it is more powerful than 120 FS. The AX is almost as powerful as my Saito 150.
I would be very happy if the DLE 20 was as powerful as AX. But my guess is it is as powerful than a 120 FS and weighs a bit more - thus I may net down in performance.
We shall see.
How do you know the DLE 20 is as powerful as the 120 AX? Is it just the published power rating?
Allan
Old 01-18-2011, 12:54 PM
  #323
Vinmech,
Take a look at your spark plug. The original will burn out, (quit?) from first start to ? Use only a NGK CM6 plug only. Easier starting, lower idle, better running, higher top end, better fuel economy, longer lifespan. And, it is SMOOOOOTH!
Steve
Old 01-18-2011, 01:07 PM
  #324
Vinmech,
Make sure the carburetor is properly vented inside of the fuselage. If it isn't, it may make the engine run really erratically. Just another thought. Check all electrical connections to make sure they are tight. Make sure all fuel lines are intact with no leaks. Hold your tongue right.
Steve
Old 01-18-2011, 01:20 PM
  #325
Because I took off the OS 120AX and put on the DLE-20 on the same plane.
<br type="_moz" />
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
