Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
What Aircraft are you installing your DLE20
Old 01-31-2011, 04:40 AM
  #401
gregg660
Default RE: What Aircraft are you installing your DLE20
Cool Jim. Shes going to become one of your favorites. Good luck with tuning out the gurgle. I can just get to the needles to adjust with the compact. Cant wait for the video. It might be a bit before I even start mine..snow snow snow. I can't run mine at home..developement no no. Have to take it to the field.
Gregg (Gas N Go)
Old 01-31-2011, 12:16 PM
  #402
jstanton
My Feedback: (14)
jstanton's Avatar
Gregg,
With the carb rotated 180 degrees and with the Jtec standard pitts muffler it is real hard to reach the needles. I had to get a small flat screw driver and bend it 90 degrees so I could adjust the needles. It works but I still have to remove the cowl to do it[:@]. I think I just my have it and I hope the weather holds for this weekend to give it another try
Old 01-31-2011, 01:12 PM
  #403
gregg660
Cool..ast least you don't have to remove it, then standard, then back to Pitts. A bent flat head. May be able to find one or two around here. Got a few flying buddies that fit that description.
Old 01-31-2011, 01:59 PM
  #404
ml3456
I know you can rotate the carb 180 degrees with no problems, but can you roate the engine backplate 90 degrees to have the needles on the side. I don't know if the cover is ported and only has one position, and I know I can get a informed decision here instead of taking the engine apart.
ML
Old 01-31-2011, 03:40 PM
  #405
gregg660
Done..cg'd Nice ..no extra weight. Lateral balanced with my wife's help as usual. No tip weight needed..nice and level.Waiting for the weather to break.
Gregg(Gas N Go)
ID:	1556523   Click image for larger version
ID:	1556524   Click image for larger version
ID:	1556525   Click image for larger version
ID:	1556526   Click image for larger version
Old 01-31-2011, 09:28 PM
  #406
bcchi
ORIGINAL: ml3456
ML
No you can not rotate the back plate.
BCCHI
Old 01-31-2011, 09:36 PM
  #407
w8ye
My Feedback: (16)
w8ye's Avatar
On the inside of the engine, the backplate has relief on one side to clear the piston skirt. Therefore, the backplate can only be in one position and that is with the relief side towards the piston.
Old 02-01-2011, 12:22 PM
  #408
ml3456
Thanks for the help.
ML
Old 02-01-2011, 04:26 PM
  #409
aa2dd
hi Foxy
I maidened my 60 stick yesterday. it has the dl20 mounted. fuel tank at cg. servos mounted at rear. with ma 16x8 prop it is awesome! straight up outta sight forever. it putts around at half throttle at old farts speed. it is a perfect combination. sure glad that i "discovered" this great combo. if you love lots of power and straight up ability, then you will be a happy pilot! and it will hover at approx 1/4 to 1/3 throttle. only thing that i am a bit nervous about is that i have about half gallon of 30:1 mix fuel thru it, and she is still spitting black out of the exhaust. i am fairly new to gasoline engines and not sure what is normal for breakin. but so far it is a strong running engine.
Bruce
aa2dd
Old 02-01-2011, 04:31 PM
  #410
ghoffman
Try it with a Vess 17-6 and you will be even more impressed.
Old 02-01-2011, 05:57 PM
  #411
microdon2
My Feedback: (47)
A 17-6 prop sounds good for 3D. How about for speed for a sport plane? I have been using an APC 16x7 and 16x8 to pull my GP 70" Revolver, and it moves nicely (including very good if not unlimited vertical). Am now looking at using an APC 15x10 or 15x12, to increase airspeed. I've also read that Xoar props are pretty efficient. Any thoughts on the best props for speed for this engine?
Old 02-02-2011, 04:34 AM
  #412
SpinnerRow
SpinnerRow's Avatar
ORIGINAL: microdon2
A 17-6 prop sounds good for 3D. How about for speed for a sport plane? I have been using an APC 16x7 and 16x8 to pull my GP 70'' Revolver, and it moves nicely (including very good if not unlimited vertical). Am now looking at using an APC 15x10 or 15x12, to increase airspeed. I've also read that Xoar props are pretty efficient. Any thoughts on the best props for speed for this engine?
I'm using an APC 15x10 Pattern on my P-51. Really good speed and on the ground about 8800-8900RPM. I tried a 15x12 and only got 8000 out of it. I like the 15x10 much better.
Old 02-02-2011, 02:54 PM
  #413
aa2dd
hi all
Looking for information guys. I have 1/2+ gallon of fuel thru my DL20 now. I have been flying it at 1/4 to 1/2 throttle with big loops at full throttle. I am still getting black gunk out of the exhaust. not sure what is normal, or if i should even be getting black crap out. I am running a ma 16x8 prop. someplace between 28:1 and 30:1 mix ratio. the hi speed adjustment is: opened up till engine started slowing down a d then back in just a tad till engine peaked back up some. Low speed jet: leaned out till engine would starve when hitting throttle, then opened up till it stumbled on open throttle, then leaned out till it answered throttle cleanly. am i missing something or is black stuff the norm for gas engines on breakon? at 1/4 throttle or so the engine runs 4 stroking. leans out to normal at hi throttle.
help me out with info guys
Bruce
aa2dd
Old 02-02-2011, 03:24 PM
  #414
Johnny_Zero
My Feedback: (44)
What oil are you using?
Old 02-02-2011, 03:26 PM
  #415
aa2dd
pennzoil 2 stroke oil
Bruce
Old 02-02-2011, 04:18 PM
  #416
Johnny_Zero
My Feedback: (44)
Just checking......Lawn Boy ashless spits real black junk.
Old 02-02-2011, 04:40 PM
  #417
foxworth
foxworth's Avatar
Thanks for the replies,aa2dd and ghoffman,love the picture. I was worried about the temperature being in the 30s this week end.
Old 02-02-2011, 04:55 PM
  #418
ghoffman
Thanks, but I am hoping it will get into the 30's this weekend. I think flying in windy, cold, and generally lousy conditions, makes you a better pilot. So does crashing my AJSlick in front of everybody! A couple of guys had the new 3D Hobby Shop foamy, and for a $59 airplane, WOW! Everybody has to have one.
Old 02-03-2011, 02:19 PM
  #419
flyalot
My Feedback: (63)
Hi,
I have the Great Planes P6E Hawk ARF and want to go gas. The projected weight range is 10 -14 lbs, 76" wing span, 1441 sq in total wing area.
Recommended engines .90 to 1.2 four stroke and .60 to .90 two stroke. Is the DLE 20 up to the task?
Great Planes website lists the DLE 30 as acceptable. Not being familiar with either engine which would provide good flight characteristics?
Joe
Old 02-03-2011, 02:39 PM
  #420
jstanton
My Feedback: (14)
jstanton's Avatar
Flyalot,
I am flying the Great Planes PF-17 with a DLE-20 and a Xoar 17x6 prop and I have more than enough power. This Little engine spins that Xoar 17x6 ay 8200RPM and creates 14lbs of thrust. So your answer is yes the DLE-20 is up to the task. [X(] The DLE-20 will fly anything a 4 stroke 125 will fly
Here is a pic of Great Plans PT-17. It weigh's in at 13.5 lbs and has a 71.5" wing span.
ID:	1558022   Click image for larger version
ID:	1558023   Click image for larger version
Old 02-03-2011, 03:05 PM
  #421
microdon2
My Feedback: (47)
flyalot - from what I've seen Great Plane's engine recommendations are on the conservative side. Their upper power range is the minimum I'll install. I currently have a DLE 20 in my 70" Revolver and it's a perfect fit (though GP's higher recommendation a 15cc). And not that a 76", 14lb plane won't fly scale with a DLE20 - it might. But you also might have no power to spare. And for just another $50 you can get a 50% larger engine? No question - I'd go with the DLE30.
Old 02-03-2011, 03:08 PM
  #422
gregg660
I agree. A bud has one with a 91 4 on her..and it flew scale. DLE 20 would be more theen enough.
Jim..video yet??
Old 02-03-2011, 03:24 PM
  #423
jstanton
My Feedback: (14)
jstanton's Avatar
Gregg,
I am still waiting for the video my friend took last Saturday at the field. I had a dead stick on the maiden flight and had no troubld with the dead stick landing. This PT-17 is a joy to fly. I tool the plane home and work on the needles and I think I now have the DLE-20 tuned right. I hope I can get some good weather for another flight this weekend. sunday looks like it might work out we are getting rain that might tuen to snow Friday night[:@]
Old 02-06-2011, 11:21 AM
  #424
e-george
Hi all,
Perfect day today for the first flight. Still air, 18deg Celcius and sunshine after a rainy week.The EDGE,although tail heavyflew nicely with its light wing loading. Two 10 minute flights logged. Although the engine was still under running in, the plane had out of sight verticals effortesly. Unfortunately, the GLASAIR was destroyedin the first flight due to radio batteryfailure after 5 minutes on air. Both DLE 20 workedlike swiss watches.
ID:	1559554   Click image for larger version
ID:	1559555   Click image for larger version
Old 02-06-2011, 01:50 PM
  #425
captinjohn
I am very sorry to read about the crash. That sure was a nice looking airplane. I could just about cry thinking about it. Capt,n
