Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
What Aircraft are you installing your DLE20
Old 01-27-2015, 08:01 AM
  #1701
ahicks
I wouldn't want anything with less wing area (850 sq. in.) because the wing loading gets pretty high - making for some heads up flying at lower (landing?) speeds. A 20cc engine on a plane that's under 10lbs. should have unlimited vertical though....
http://www3.towerhobbies.com/cgi-bin...&I=LXBAEE&P=ML
Old 01-27-2015, 03:34 PM
  #1702
FlyBoy95
Thank you very much ahicks ill have a look for aircraft that have areas above that.
The GP .60 stick has a wing area of 1000 in^2 so it should work.....
Im just addicted to the idea of less glow mess and halving the price of fuel
Thanks again
FlyBoy
Old 10-07-2015, 05:17 PM
  #1703
sparkshooter1
I am getting ready to start the same project. Twin 20s with retracts. Does DLE sell the synchronizer?
Old 01-27-2024, 02:01 AM
  #1704
one23fly
Hi All,
I have a scratch built super sportster 90/120 - came out a tail heavy, so had to add a bunch of nose weight, dry AUW is 12.5 lb. Will a Dle 20 w/ 17x6 Xoar wood prop be fine for this model?
- Thanks
Old 01-27-2024, 04:05 AM
  #1705
Lifer
Lifer's Avatar
A 20cc gas engine will give good performance at that weight. Most of my 20cc warbirds weigh around 14 pounds and fly well.
one23fly (01-27-2024)
Old 01-27-2024, 09:21 AM
  #1706
kmeyers
kmeyers's Avatar
I use DLE 20's in this size plane as well (currently 3). They fly great, but, wilder slower I use the 17 x 6 and a plane like the sportster I use a 16 x 8 (currently in a Venus II).
Old 01-27-2024, 11:35 AM
  #1707
Steve
My Feedback: (54)
Steve's Avatar
I've got one in an 11.5 lb U-Can-Do 60 and it's a great match up.
Old 01-27-2024, 12:26 PM
  #1708
Lifer
Lifer's Avatar
DLE 20's can use a variety of props. 17x6, 16x8, or the APC17x8N (narrow) which will out-turn and out run the 16x8 all day long. It's quieter as well because it is much more efficient.
Old 01-27-2024, 02:11 PM
  #1709
Tailspin
Tailspin's Avatar
I have a Hanger 9 PT-19 and Christen Eagle with the DLE20 RE .
The 80" PT-19 is a good sport flyer and the bipe is a little rocket ship.
Steve
Old 01-27-2024, 09:29 PM
  #1710
one23fly
Thanks all for your replies. Should I use a 17x6 or 16x8 prop. Have both.
