G62 vs DLE55
Old 09-04-2011, 04:44 AM
chris923
My Feedback: (53)
Default G62 vs DLE55
Gentlemen,
I know this question can be easily be answered by the experts, Antique, Jodi, Ple ect.
Which has more HP G62 or DLE55?
Chris923
Old 09-04-2011, 10:48 AM
mmn
Default RE: G62 vs DLE55
ORIGINAL: chris923
Gentlemen,
Chris923
Curious. Why wouldn't you just look it up? Specs for both are available on line.
Regards
Michael
Old 09-04-2011, 10:57 AM
skillet92
I think he wants real data not factory advertisement. I have a 55 and it is a beast.
Old 09-04-2011, 03:13 PM
w8ye
My Feedback: (16)
w8ye's Avatar
A G62 can be a beast also if it is set up correctly.
Old 09-04-2011, 03:17 PM
Edwin
I have both. Hard for me to tell. The G62 is magneto, the DL50 is electronic. But I am just a sport flyer so my opinion might not be worth much.
Edwin
Old 09-04-2011, 03:31 PM
w8ye
My Feedback: (16)
w8ye's Avatar
The G62 can weigh more than a DLE 55 unless you have one set up like one of Ralph Cunningham's G-62 lite's.
A G-62 does better if allowed to turn up a little rpm.
ID:	1657646   Click image for larger version
ID:	1657647   Click image for larger version
Old 09-04-2011, 04:01 PM
Kweasel
My Feedback: (29)
The DLE performs better at lower rpms and the G62 at higher.
Old 09-04-2011, 04:37 PM
mrbigg
My Feedback: (21)
mrbigg's Avatar
A G62 can rip a 21 pound plane out of a hover if propped correctly. Wasn't my plane, but I seen it/flown it.
Old 09-04-2011, 04:53 PM
Jezmo
Jezmo's Avatar
Properly set up they are both strong engines and as mentioned one is better up high and the other down a little lower in the rpm range. They will both yank a 30% or 50cc 3D bird out of a hover like a rocket, they just require a different approach to get there.
Old 09-04-2011, 05:49 PM
w8ye
My Feedback: (16)
w8ye's Avatar
The DLE 55 is a closed port engine
The G-62 is a open port engine
Closed port two strokes generally have more low end torque.
Old 09-05-2011, 05:55 AM
Jezmo
Jezmo's Avatar
One other major difference is one is piston port inducted, the G62, and the other, the DLE55 is reed valve inducted.
Old 09-05-2011, 06:31 AM
chris923
My Feedback: (53)
Gentlemen for your input.
You all confrimed my thoughts, that both engine are pretty close, depending on set up.
I have a DLE 55 in aTF P-51, flys like a rocket. I have been working on ( almost complete)
TF P-51B. That one has one of Ralphs G-62 lites in it with a custom ( designed by me, welded
by a buddy) scale exhust.
By next spring the I'll have both in the air, and I can make a closer comparison.
Chris923
Old 09-06-2011, 07:54 AM
[email protected]
My Feedback: (21)
Having flown g-62's in warbirds for years and having seen the DLE55 fly in a warbird I will be shocked if the G-62 won't blow it's doors off! Of course it has to be propped right.
A 22X8 on a G-62 is all right for a mustang but get the revs up with, say, a 20X10 carbon fibre or a 21X10 wood and watch out. The G-62 loves rpm. I believe Ralph says they have run them up to 13,000 on the AT-6's with a special prop.
Larry
Old 09-06-2011, 09:16 AM
Tired Old Man
In general terms the 62 is the stronger engine. The 55 is no slouch but the 62 will propel a much heavier aircraft.
Old 09-06-2011, 12:06 PM
MetallicaJunkie
MetallicaJunkie's Avatar
if i was into warbirds, racing or speed G62, for 3d DLE55 hands down........ they both have their place.... if i wanted a sport engine that would probably outlast my air frame i'd pick a g62 as well
im trying to as unbias as possible
Old 09-06-2011, 01:11 PM
Antique
Antique's Avatar
ORIGINAL: [email protected]
Larry
Nope, 9000 unloaded in the air with an open header with the APC USRA race prop...
Old 09-06-2011, 02:33 PM
[email protected]
My Feedback: (21)
What was I thinking of? Maybe GT80 on alky?
Larry
Old 09-06-2011, 02:52 PM
Tired Old Man
13,000 is about where a 3.2 Brison says goodbye to the rod.
Old 09-06-2011, 03:18 PM
WhiteRook
My Feedback: (38)
whats the difference in weight, for those who need nose weight.
Old 09-06-2011, 06:42 PM
vertical grimmace
vertical grimmace's Avatar
My next project will be getting the G62. The model was designed with the DA 50 or DLE 55 in mind, but really, I want the magneto. I want the nose (warbird) weight, and the reliability of the mag. Just one less battery to worry about. A spring starter will be in order as well. Reliability is the primary objective here, and the G62 fits the bill for sure. the price is great as well.
Old 09-06-2011, 06:58 PM
Tired Old Man
If you aren't less than 15 years old the 62 should last longer than you will
Old 09-07-2011, 10:09 AM
vertical grimmace
ORIGINAL: Tired Old Man
With any luck, the plane will as well!
Old 09-07-2011, 11:32 AM
Tired Old Man
One can only hope. The only assured way to make that happen is to never fly it
Old 09-08-2011, 10:22 AM
vertical grimmace
Where is the best place to buy one of these G62's? Should I just go to Bennett? No EI for me, I want mine stock.
Old 09-08-2011, 11:27 AM
flygilmore
flygilmore's Avatar
............From someone who has one NIB with good ratings!! These things are near bullet proof-even the used ones. I sure love mine.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
