DLE 20cc carb wont pump fuel.Help!
Old 09-22-2011, 12:40 AM
hillcares
Default DLE 20cc carb wont pump fuel.Help!
I just installed my dle 20cc to supercub,i have noticed the fuel wont go to the carb even if I cleaned already the carb membrane,flip the prop.I already break in this engine in my bench for 1/2 gallon.What did I miss?thanks
Old 09-22-2011, 02:40 AM
Lifer
Lifer's Avatar
Default RE: DLE 20cc carb wont pump fuel.Help!
Check the vent/overflow line. It should breathe freely. Also, sometimes you need to direct prime the engine until it starts and gets fuel to the pump membrane.
Old 09-22-2011, 05:22 AM
a1pcfixer
My Feedback: (7)
a1pcfixer's Avatar
Since you claim to have already bench run the eng, I'd be looking at your fuel lines.
Carb fuel line connected to clunk line from tank (NOT the vent line?)
Vent line not being restricted by being crimped somewhere?
No air leaks?
All connections in fuel line have zip-ties (to prevent air leaks & keep clunk on)?
Old 09-22-2011, 07:56 AM
Antique
Antique's Avatar
Be sure the membrane with the metal center is on top of the gasket on that side.
The other membrane goes against the carb under the gasket
Old 09-22-2011, 01:09 PM
Jezmo
Jezmo's Avatar
Check the diaphragm/gasket assembly order like Ralph says and if they are correct then look at all of your plumbing as Jim suggests. I usually plug my fuel pump hose into the hose going to the carb and pump fuel in and out of the tank - I'm looking for leaks while pumping fuel in and bubbles in the hose while pumping fuel back out. If you are getting bubbles in the line then you have a leaking connection that must be fixed. The volume is too small on the carb pump to overcome any air leaks in the plumbing. If it ran fine on the bench and now has fuel draw issues then something isn't right in the plane's fuel system.
Old 09-24-2011, 09:39 AM
hillcares
Thanks for the help guys!
Old 09-24-2011, 11:06 AM
a1pcfixer
My Feedback: (7)
a1pcfixer's Avatar
Did ya get it fixed?
Which was the problem?
Old 09-24-2011, 04:16 PM
hillcares
yes I solved the problem.its the diaphragm that I installed incorrectly.Now its pumping ok.thanks
Old 09-26-2011, 09:46 PM
Octopus RC
Did you check the reeds inside of your valve block ?
Old 09-26-2011, 10:14 PM
MetallicaJunkie
MetallicaJunkie's Avatar
ive put a membrane backwards one time( a long time ago)... the petals were of and the engine would only cough and pop...i was stumped and the local lawnmower shop "fixed" it for me
