Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
Timing a RCexl without degree wheel
Old 12-06-2011, 07:50 PM
BadAzzMaxx
Default Timing a RCexl without degree wheel
Here is a link showing how to time a engine for RCexl without using a degree wheel.
http://www.rcextremepower.net/ignition_timing.html
Also here there are some neat new products coming from RCexl in 2012.
Milton
Old 12-06-2011, 08:17 PM
bcchi
Default RE: Timing a RCexl without degree wheel
ORIGINAL: BadAzzMaxx
Milton
Boy that Ralph is trickey.Plus being grumpy.This is much eaiser then measure the paper thing.Of course I use the TLAR method or eyeball timing.
BC Used to be BCCHI.
Youll never no how little I really care.
Bill
Old 12-06-2011, 09:22 PM
Antique
Antique's Avatar
OOPS 3.14 not 3.4
Old 12-06-2011, 09:29 PM
BadAzzMaxx
oooops, corrected.
Milton
Old 12-07-2011, 04:13 AM
soarrich
My Feedback: (98)
soarrich's Avatar
ORIGINAL: bcchi
The paper thing was invented because some people are just adverse to math of any kind.
Old 12-07-2011, 06:16 AM
Whistling Death
Whistling Death's Avatar
ORIGINAL: soarrich
ORIGINAL: bcchi
Or for people who don't own a dial caliper.
Old 12-07-2011, 06:55 AM
Antique
Antique's Avatar
Dial caliper is a very handy thing to have, cost around $10 from Harbor freight or Ebay..Sometimes free with an order from Boca Bearing....
Old 12-07-2011, 07:54 AM
BadAzzMaxx
If you do not have calipers, You can do it with a measuring tape and a couple blocks of square wood on a flat surface.
But the calipers are so cheap anyone in the hobby should have one.
Milton
Old 12-07-2011, 08:02 AM
Whistling Death
I own two Brown and Sharpe's but you are right, at that price, anyone that is in this hobby have a set.
Old 12-07-2011, 08:16 AM
BadAzzMaxx
Yep, Pay $15.00 for a servo arm, $10 bucks for a good tool sounds cheap. LOL
Milton
Old 12-07-2011, 09:03 AM
Whistling Death
Milton
Ah, but it isn't an "RC Caliper". If that same caliper was rebranded and sold by Dubro or Hobbico it would cost you 3-4 times as much. [>:]
Old 12-07-2011, 09:35 AM
a1pcfixer
My Feedback: (7)
a1pcfixer's Avatar
FleaBay has 'em........
http://compare.ebay.com/like/3902468...=sbar&_lwgsi=y
Old 12-07-2011, 09:54 AM
HunkaJunk
I have done something similar on 2 strokes where I didn't have access to the output shaft. I found TDC and BDC, and measured the distance of each with a depth gauge (measured through the spark plug hole). A little mathematics gave me a distance for the desired degree.
Old 12-07-2011, 11:07 AM
w8ye
My Feedback: (16)
w8ye's Avatar
This finding of TDC and BDC directly does not work because of the sweep of the connecting rod big end.
It must be done as Milton explains it.
Old 12-07-2011, 12:14 PM
av8tor1977
av8tor1977's Avatar
YEP. The positive stop method as shown is the only sure way to find true TDC. That's the way it is done even in super high dollar auto racing.
AV8TOR
Old 12-07-2011, 03:30 PM
Antique
Antique's Avatar
Or in the case of a straight up spark plug, an old spark plug with the porcelain bored out to fit a cheapie 0-1 depth dial indicator...
Old 12-07-2011, 04:56 PM
MetallicaJunkie
MetallicaJunkie's Avatar
ORIGINAL: Antique
i find TDC the way i learned in a video on you tube..... where can i get a cheapie dept dial indicator?
Old 12-07-2011, 05:08 PM
captinjohn
ORIGINAL: Antique
Now we are talking something good! That gets my vote....Capt,n
Old 12-07-2011, 05:16 PM
blikseme300
My Feedback: (118)
ORIGINAL: MetallicaJunkie
ORIGINAL: Antique
You can get one for about $20 at Rex Supply, 1313 West Ferguson Street Pharr, TX 78577 - (956) 781-7761
They are a great local source for machine tool things.
Bliksem
Old 12-07-2011, 05:18 PM
w8ye
My Feedback: (16)
w8ye's Avatar
The only way to accurately find top dead center is to accurately stop the piston at the half way point in both directions and then select a degree point half way in between these two.
This is the method Milton talks of.
Directly measuring BDC or TDC with a dial indicator, it would be more accurate to feel for TDC with the prop and then make the timing look about right like Bill does?
Old 12-07-2011, 05:40 PM
captinjohn
ORIGINAL: w8ye
It is not so much the way or tools you use to find top dead center. It is how accurate the person is inusing the tools in the right manner. Capt,n
Old 12-07-2011, 05:54 PM
MetallicaJunkie
ORIGINAL: blikseme300
ORIGINAL: Antique
Bliksem
thanks Carl
Old 12-07-2011, 06:37 PM
av8tor1977
av8tor1977's Avatar
Ralph, you know very well that a dial indicator won't give you true TDC unless you use it to measure a specific distance on either side of TDC and then split the difference. That is the only way to eliminate the dwell time of the piston at TDC as the crank goes across its travel. I know, it is "splitting hairs" a bit as far as timing these little airplane engines, but correct is correct right??
AV8TOR
Old 12-08-2011, 07:30 AM
captinjohn
I am sure Ralpf (the Antique one) knows how to use a dial indicator and any machine tool related to RC. It is simple. Say the stroke of the engine was 1.000 inch. Just lower the tip of the indicator .500 and that will be mid travel of the piston. If a guy cannot figure out the rest.....forget buying a indicator. Go play some pocket pool!!!! Capt,n
Old 12-08-2011, 08:17 AM
Antique
Antique's Avatar
Actually guys, I don't use anything..been doing this long enough to know where TDC is by feel...The middle of the dead spot when the piston is alll the way at the top...A few degrees either way makes absolutely NO difference in the way the engine runs....ONLY engine I ever found to make a difference was a 289cc race engine...Ran just as well at 22 BTDC as it did at 28....Tming is much ado about nothing, just like oil ratios and brands...Use what works for you....
