New for welding
I found this device online and am wondering if anyone has tried one. It sounds like a nice welder that a peron who makes exhaust parts for resale, shoud have...maybe? Capt,n
http://www.multiplaz.com/index
IN
One thing I don't understand is they tell you to use a water-alcohol mix to generate a shielding gas. Then they warn you not to use methanol as it generates toxic gas and the manufacturer takes no responsibility if you use methanol. So, what alcohol do they want you to use? They never say. Perhaps they are saying that any alcohol generates toxic gas and their plasma welder is unsafe to use?
ORIGINAL: Diablo-RCU
edit
http://www.multiplaz.com/pdf/Multipl...w_20110418.pdf
page eight
it says you should use ethyl alcohol...aka booze.... now there is a use for cheap vodka
it can also cut through cement, concrete, brick, haydite aggregate, quartz glass, etc.
One thing I noticed they dont give a close up view of any of the finished welds. Being a former sheetmetal worker I think I would prefer a tig welder. Cheers the pope
ORIGINAL: the pope
after reading this http://www.hobartwelders.com/weldtal...524-multi-plaz
the welder works, the welds just aren’t "purdy"
I’m wondering if it is a practice practice practice problem or a problem with the machine
imo it is a practice issue, seems to be a totally different style of welding and a voltage/temp issue…different material….different temp….just needs some fine tuning
either way dedcated machines almost always work better but for car/hobby/household/random needs it looks like it will work perfectly
Well I tell you all what..I can't figure out why you would pay 2000+ for this thing when 1500 will get a pretty nice TIG welder that that can be used to weld virtually any common metal used in RC. Granted you can't buy the skill to use it. Probably can't get the skill to use this thing either... Never saw any welds or cuts for this thing. I'd bet even a neophite could operate my TIG welder if I gave the lessons.
So now as I tell my hotrod friends (I tell them much more point blank than my RC friends) After you have botched the job with make shift stuff and bring it over to have me fix it, I charge once for the repair and again for not bringing it over before the botched repair. The penalty clause. haha
Now tell me that you don't think a nice TIG weld either on steel or aluminum doesn't look good. "Ain't purdy", ain't gonna git it especially if you have to pay to have it done.
As for the cutting process, I build 250 mph drag race cars and there are few parts that require any hot cutting except when they get busted up. I can't think of anything in RC that needs cutting with high heat. The ony heat I can think of is the heat from a match to get the fire started after a crash...haha
Sorry I'm a naysayer on this one.
To each his own. I'm not going to be building any 250mph dragsters and anything that keeps me from having to piss around with the local gas distributor is a huge plus.
The fact that I can put water in the thing and start welding makes it pretty convenient.
A rig like this opens doors for the tinkerer/fabricator.
CO
ORIGINAL: bentwings
Now tell me that you don't think a nice TIG weld either on steel or aluminum doesn't look good. ''Ain't purdy'', ain't gonna git it especially if you have to pay to have it done.
