Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
Dubros round nose tank has less useable fuel
Old 12-16-2011, 06:54 AM
griesel
Default Dubros round nose tank has less useable fuel
I had a Hempel Yak 55M 50CC with a Dubros 424 round nose 24 ounce tank
in it.I was landing with a slight nose down attitude; about 500 ft. of down wind;
400ft of cross wind and 200 ft of final when I decided I was still too high and
open up the throttle, to about half, to go around the engine picked up normally
and ran for about 3 seconds then died. I mishandled the dead stick landing
and crashed. Post crash analysis revealed the fuel system was OK with
7 ounces of fuel remaining. What I believe happened is that the fuel went
forward with a large amount going into the round nose exposing the klunk
and causing a dead stick. This was my first and last round nose tank. I
am sticking with rectangular tanks now on. This was corrected. I originally
called it a Sullivan.
Old 12-16-2011, 09:50 AM
Lnewqban
Lnewqban's Avatar
Default RE: Dubros round nose tank has less useable fuel
Sorry to read about the crash.[]
What specific tank were you using?
I believe that the slant type is the only 24 oz tank that Sullivan offers.
Old 12-16-2011, 11:47 AM
griesel
Corrected to correct tank
Old 12-16-2011, 12:49 PM
blikseme300
My Feedback: (118)
Sorry to hear about your accident. What clunk were you using?
I have used Walbro felt clunks exclusively in this style of tank and have run tanks dry during flight. 7oz left in tank sounds like you had a plumbing problem and a rectangular tank would probably not have helped. Just sayin'.
Bliksem
Old 12-16-2011, 01:58 PM
MetallicaJunkie
MetallicaJunkie's Avatar
i use felt clunks too... and they do run the tank completely dry as mentioned above
Old 12-16-2011, 03:27 PM
Truckracer
My Feedback: (19)
Certainly with 7 oz. of fuel left in the tank, the shape of the tank was not the problem. In a normal fuel system there is enough fuel in just the outside fuel line and clunk line to keep an engine running through any normal approach and landing.
Old 12-16-2011, 05:07 PM
griesel
Yes if I had landed with the throttle off or nearly off. But I went to 1/2 throttle and used
up the fuel in the line in about 3 seconds.
Old 12-17-2011, 06:08 AM
exeter_acres
exeter_acres's Avatar
ORIGINAL: Truckracer
that is correct...
more than enough...
Old 12-18-2011, 02:28 AM
liquid_TR
liquid_TR's Avatar
I also dont like those round nose tanks, and never use them. However in your case that cannot be the reason for dead-stick.
When you apply throttle, even for a split second the fuel in the tank will move backwards because of acceleration, and stay there.
you dead-stick happed either because of bad plumbing, air-leak, ignition failure, opto kill fail, bad plug, mis-tuning or bad fuel.
pick one.
