Why Gassers are more addictive or better than Glows e?
My Feedback: (10)
Hi y'all,
Since I'm flying outta USA to visit my family and for my sister's illness who is feeling much better Thank GOD, I thought that I would like to have the experiences of all those expert r/c mentors, experts, fliers and those transitionary people like me who are transitioning from glow to gasser. My thing was I got to return my Revolver 40 with a loss of whopping $20 lol and able to get DLE20 and I was looking for a 60 size plane, and through Nitro planes, I got yak 54 120 for $156 shipping now the price is itself $150 or something.
Since gasoline is cheaper than glow fuel, and big planes fly better but I think that your expenses get spiked up rather than getting plummeted by moving to gas from glow?
Bigger ARF's means bigger prices, of course with the flooding of Chinese engines it looks like people would stop using glows engines and get more gas engines, you need other itty bitty other stuff for gassers, props etc etc etc. Since planes are bigger so they fly better so does it mean bigger planes are less likely prone to crash as compared to small sized airplanes?
Since I've already gotten my first project of gasser which I would be working on after second week of January 2012 under the wing of my mentor, and feel lucky to have one, since mentors ain't a dime a dozen.
I'd like your experiences, updates, inputs and persuading comments why gassers are better than glowers?
Mody
Mody
RE: Why Gassers are more addictive or better than Glows e?
For me after starting my first gasser for a plane I was building, I knew nitro was a thing of my past.. For me gas is less fuel cost, no clean up after flights, easier starting, easier tuning and better sound. Also less equipment to take to the field. No more stater's, glo igniter's, field boxes or field batterie's. All I take to fly now is a plane, the radio, and fuel. Yes maybe a little larger airframes but with that come's a more stable aircraft, and easier to see. I still have several nitro powered aircraft. And have not flown the first since that first gasser started.
I think I got into gas out of curiousity. Then I got a few deals on used planes. Now I have a 12 plane stable of gassers to maintain. The only real advantage of gas to me is less mess. I don't mind cleaning my glow planes since I started using Krud Kutter, but at the end of the day it is nice to just put the plane in the car and go. HOWEVER, if I have only a couple of hours to fly I will grab my GMS .75 powered .40 trainer and go to the field for some fun. Got it from Texas RC Planes. Has a wing more like a Stik type plane than a trainer. Lote of fun.
My Feedback: (10)
A .90 two stroke glow will outperform most 20cc gassers in a hearbeat, yet weigh around half og the gasser. Above 20cc, there is no question
My Feedback: (7)
IN
Weak argument when comparing a DLE20 to similar glows (1.20).
That DLE20 is somewhere between a glow 1.20 -to- 1.50 for output.
Weight differences are negated when you consider the DLE20 needs only about half the size tank the similar sized glow requires.
Add in the fact the DLE20 can swing a 18 x 6 prop (but does best on a Vess 17 x 6), and the thrust figures easily favor the DLE20.
If bragging rights of high rpm is your thing, stick with a glow.
If thrust/torque and overall economy mean more, go with the DLE20.
Any 20cc gasser that spins a 15x8 at only 7,500 rpm is very weak indeed, and certainly not what I would consider as typical.
Karol
Karol
For me, the attraction is more 4-stroke vs 2-stroke because of the better noise, grunt, less mess and fuel economy. I've tried 2-stroke gas, but have gone off it because of the noise. I've currently got a couple of Saito 4-stroke gas engines, but they are expensive to buy. I don't think there are any other commercially available small size gas 4-strokes? I've still fly nitro 4-strokes. I won't buy any more 2-stroke nitros or gas engines.
For me it is the sound of a 3 cyl Four stroke engine that turns my head. Some very high output 2 srtrokes are sweet too. Here is my favorite now.... http://www.youtube.com/watch?v=5PnJkBl0Ql8 Capt,n
My Feedback: (10)
I'd agree with y'all when it comes to gasser specially 20CC and DLE20 there is no comparison to .90 size glow. Since it's gonna be my first experience, so I'd try my utmost to keep this forum alive and keep y'all posted with this noob's new experience. I bought Zinger wooden prop 16X6 for me DLE20 for yak 54 120 of nitro planes.
Zingers don't seem to have true pitch. A 16x6 might be a 16x5.5 when it gets in the air. Some say they flatten out under load. For a prop to have proper pitch the hub has to be as thick as the pitch when they machine the wood away. So an 8 pitch should be slightly thicker at the hub than a 6 pitch. I like the Xoars in the larger planes.
The JXF and Hawk props are identical to the Xoar in both design and performance and are a bit more economical in price.
Karol
Karol
ORIGINAL: apalsson
Sure can,
A common two-stroke glow engine, OS95AX is rated for a 14x8 prop (15x6 is pretty much the same load) and you should expect near-on 9,000RPM - probably more. This engine weighs some 745 grams
A typical 20cc gasser swing a 15x8 at around 7,500 rpm, however all-up weight (including ignition) will be around 950grams when you include the ignition battery
Please note that I suggested a 20cc was the point where I saw gassers come into their own.
The many common 15cc, 17cc etc perform less than the 20cc but weigh roughly the same
Sure can,
The DLE 20 is the engine that made me give up glow after 20 years flying glow. THere are lots of .90-1.20 airframes that it will fit on. The 1.20 sized airframe is a good size for me. The servos aren't that expensive and there is plenty of room for the DLE 20. And the planes aren't so big that they're a problem to transport.
My Feedback: (26)
Gas engines did not just appear on the market, remember Qudra. Qudra was the leader and it was imported from Canada. What was the motivating factor? Could it be the Chineese imports just like the wave of ARFs manufactured airframes. Japan imports engines and electronics. They used to be R/C products of choice however our government imposed an import tax on these items. Presently there is no such thing imposed on Chineese products but IMO it is coming. Does anyone no why nitro fuel is so expense it's called government regulations and presently there is only one manufacture in the USA providing the key ingredient nitro methane. Our own hobby industry could not compete with foreign manufactures and now we rely on imports.
ORIGINAL: flycatch
ORIGINAL: w8ye
All the nitromethane is made in China.
The one company that made it in this country quit making it and just buys it from China and resells it.
My Feedback: (19)
ORIGINAL: armody
My Feedback: (19)
ORIGINAL: SpinnerRow
Hell, I wonder if I'm made in China? Everything else is!
ORIGINAL: w8ye
<hr />This is so true. The small gas engines will work in many,many airframes out there easy to fine...new or used. I wish I had time to try them all!!!!!!!!!!!!! Capt,n
My Feedback: (19)
I believe that gas powered planes are popular for a number of reasons beyond just the differences in the engines. If it was just the engines, I don't believe arguments in favor of gassers would completely offset the really high quality glo engines that are available these days and the positive experiences one can have using them. Yes, I know the glo mess, the high cost of fuel, etc. those things have been beat to death and are certainly true but glo engines can be extemely high performance and just as reliable as any gasser so there must be other reasons for gasser popularity.
For me, gassers are my favorite power source mostly because of the whole package they get bolted to. Gas powered planes largely evolved into ones with fuselage mounted landing gears and with wings that slide on to tubes. Along with these features they also have top hatches that expose most of the internals including the tank. Remember having to jam those nasty tanks and fuel lines into the noses of glo planes? Much easier on gassers! The plane just sits there on the bench and is extremely easy to work on and maintain. Same at the field, with just a few tools the plane is assembled and ready to fly. Much simpler than most glo planes with their one piece wings that bolt on the bottom of the fuselage. Yes I know many glo planes have also evolved into this same gasser type of construction but I would suggest they are in the minority with traditional glo designs still most popular. Certainly there are other forms of gassered powered planes but I bet these don't get flown as much as the type mentined above. If you have to take an assembly stand out to the field to assemble a plane on, I guarantee that plane won't get flown as much as the one that stands on its own feet.
So its the overall flying experience that makes gassers popular. The engines and their airframes are easier to maintain, use cheaper fuel, offer long troublefree life, etc. the list goes on and on in favor of gassers.
let me consider this for one second,,,,,, no i will stick with my glow engines, cant stand the stink of petrol in my van or garage, my moki 210 35cc pulls my sig sundancer around with bags of power and
has very little vibration, sounds great with a bison muffler and no i dont have to bolt on extra cannisters etc to try and keep the noise down, what mess?? a quick wipe down at end of day, oh and it runs
fine on no nitro, same as my super tigres in my pitts and gilmore, fuel costs a few dollars more but i mix my own so its pretty cheap, also i dont have to buy batteries kill switches and whatever,
i have a number of glow engines 2 and 4 stroke and cant remember my last deadstick and if they dont start within a few seconds i look for the problem, i see plenty of gas engines giving owners headaches
on most flying days, i think this rush to gas engines is a bit like the emperors new clothes, in my view a glow engine is lighter,quieter, vibrates less and sounds much better, maybe im wrong,,,,,,
saying this i like to fly up to 50 cc size planes and agree that above that gas is the go, just my 2cents worth
