Gas tank question
MyDewey came with this funky tank in it, has never been filled. The fitting on it is a sleeve and insert, and comes out fairly easy. Just wondering if it would be safe for Gas.
The line may swell somewhat from gas, making it hard to slip apart. Just try it and see....if it does not seem to work, try a different fuel tank. Use ines made for Gas. Capt,n
That is a Tygon line in it now. I changed it out with the black one that was in there. The tank has a vent outlet and it looks like the fill one is plugged.
I have a similar tank I got in a kit from Hobby Lobby which Iused in a gas plane. But after about a dozen flights found that vibration from motor had caused the plastic outlets (which are moulded into the tank simiar to your picture) to crack and leak. So went back to using the old style tank with rubber stoper and brass tubes.
ORIGINAL: gofast53
My Feedback: (17)
FL
The big problem (in my eyes) is that that tank will not allow for much of a clunk.
I recently removed one from a plane I traded for and with the size of the hole there is no way I could put a heavy enough clunk on the the line to make me comfortable that the tubing would be able to flex enough.
Paul
Paul
