New DLE 35
#251
LA
RE: New DLE 35
ORIGINAL: MTK
Tower Hobbies...with the super saver coupon, it cost $300 with free shipping. Reasonable and probably better than most. The 10$ membership has more than paid for itself over the past 12 months. It's worth a good look if one is planning to buy some equipment in a year's span.
If any one is interested, I have a NIB muffler for the DLE35RA. I don't use the stock units since I use pipes and cans on my set-ups. Contact me direct to my email addy below.
In fact I am currently evaluating several canisters for Ed Skorepa of ES Composites. These are gorgeous carbon canisters, very very quiet. So far none have been tuned canisters meaning no jump in rpm was noted. But the R&D has just started.
ORIGINAL: RC_AVIGATOR
So where did you buy your motor?
I just finally got mine in from Tower about 2 weeks ago at which time it had been on backorder w/ a $60 off membership price - this had been on backorder since around Christmas .Really could not figure out why Tower did not have them in and everyone else did?? Didn't need the motor right away and could wait for the backorder ( 90+ days).
So when did you get yours without the "plastic tubes" and is that the one you will part with?
#253
RE: New DLE 35
BUT the PTFE tubes will work fine. There's no need for the clunky hose clamps tho. A pair of small 4-40 button heads on the stubs will retain the PTFE tube with a simple tie wrap.
One thing folks will notice is that with use, PTFE will turn bluish grey. That's nothing to worry about. Exhaust oil (black) coats the inside of the tubes. Light is mostly absorbed by the black residue but the blue reflects and that's what you see
#254
RE: New DLE 35
Been conferring with Denny a B&B about making a Bennett muffler for the 35RA. I want to use one of them because it has a smaller profile than the stock muffler. Should be on the market soon.
#257
RE: New DLE 35
ORIGINAL: airraptor
i havent ran mine yet but i dont like how close the muffler is to the back of the engine. might as well not have any cooling fins there unless you baffle the engine so that the air flows from one side to the other ( in the direction of a side exhaust).
#258
My Feedback: (8)
RE: New DLE 35
I have been running a DLE 35RA longer than anyone outside of VVRC and I have yet to experience ANY overheating issues. Mine is in a warbird and spends 95% of it's time at full throttle. There was also concern about the carb being so close to the muffler. Another non-event. Just run it and you'll see why so many of us like this engine so much.
#259
My Feedback: (66)
RE: New DLE 35
rc guy that may be true but i bet the front of the cylinder is around 200 degrees and the the back of the cylinder near the muffler is 400. Even if 300 what this means is the cylinder is expanding at different rates and causes the cylinder to go out of round and loose some rpm. now some may never know the power lost but there is power to be gained by better cooling. Thats all I saying. i will run my with the Macs header and custom mufflers
#260
RE: New DLE 35
ORIGINAL: airraptor
Hi
You maybe right ,.............................. but ,.... he,s having fun , and not complicating things . It,s a hobby ,............ not NASA .
Michel
#261
RE: New DLE 35
ORIGINAL: airraptor
#262
My Feedback: (66)
RE: New DLE 35
I am always looking for more power lol. yes the stock set up cools it OK. most of the wrap around mufflers are round and not square like this miffler. if you look at air will flow around the cylinder you will see the air is stagnating inbetween the and just above the muffler bolts.
#264
RE: New DLE 35
Do you guys think we'll soon see a DLE 35 with an Electric starter http://www.youtube.com/watch?v=UH_Je...ture=endscreen
#265
RE: New DLE 35
ORIGINAL: ameyam
Hi,
how does the power of the dle 35 compare to the is gt33?
Ameyam
Hi,
Ameyam
Electric airborne starters? Geez, why? The extra equipment the model will need to carry is heavy. Besides the DLE35 starts so easy why even think about electric starters?
On the other hand, hands off starts add lots of "BLING" and some guys really like that aspect of modeling, maybe more than the flying
#267
RE: New DLE 35
ORIGINAL: airraptor
MTK can you post numbers o nthe muffler for both engines. You have put a lot of time in the 33. i would think you would like the 35 over the 33 for less weight and easier exhaust set up (cleaner plane profile).
Indeed I love the rear exhaust config of the 35.....Weight difference is negligible in my set-up
But powerwise it isn't that close to the 33 at throttle settings that I want to use. The mid range of the OS33 is really remarkable while the mid range of the DLE35 struggles. That's engine design in my view. OS has very interesting porting plus almost 10% longer stroke which enables the mid range and large load capacity
I use 20 x 10.5 APCs on the 33 and get around 7500 rpm on Avgas and about 7800 on premium auto gas. In contrast the 35 is being run with first a 19x10 (around 7000) and now an 18.5 x 9.5 (around 7200). But I'll tellya that when I am at mid throttle and turn a vertical corner, the 33 with the big load up front just keeps chugging and pulling like a truck on low gear climbing a hill. It's just like a YS 4 stroke big block 175.
Do the same with the 35 and it chokes, needing a throttle bump. To be fair, the DLE really needs another2 gallonsor so to be broken in more fully; has just over 1 gallon through it so far. It also has a Bowman ring in it
Then it's the plane weight each is hauling. The 33 is hauling an 11# 5 oz pattern model and the 35 is hauling a 10# 6 oz pattern plane, so one would expect the lighter plane to zip with greater authority. Not so.....due to the prop difference
Lots more thrust with the bigger prop disc.
I use a piped set-up on the 33 GT and a canister on the DLE35 so exhausts are not exactly the same as yet. I have a pipe coming for the DLE this week.
The OS's tuned exhaust set-up is a little more involved, true that. The DLE's exhaust set-up is simpler, straight back
#268
RE: New DLE 35
ORIGINAL: MTK
#270
RE: New DLE 35
ORIGINAL: SpinnerRow
HUGE difference between a Canister and a pipe! 7-800RPM probably.
#271
My Feedback: (66)
RE: New DLE 35
I have a ES carbon pipe for my 55 and only saw about 500 gain over the stock muffler on a 23x8 prop. The ES carbon pipe to me really isnt a pipe perse but a semi tuned muffler. I think a real tuned pipe would see even better gains on the 33 and 35 but it would be around 5 inches across and not fit in many planes lol
Anyway MTK not knocking the 33 just wanted to see numbers on how close or far off it was. the longer stroke really helps in the torque area.
now if the OS 33 would make a rear exhaust and use a AAC sleeve then would be an awesome engine.
#272
RE: New DLE 35
ORIGINAL: airraptor
Regarding the OS 33..... If I could afford one of those, I'd have one as well. They sound like real torque monsters.
#273
RE: New DLE 35
I get 8-900rpm over the stock muffler with an ES Carbon pipe on a DLE 20.
#274
RE: New DLE 35
ORIGINAL: MTK
On affordability. I use the Tower Super Saver, $60 on items over 300. That brings the price down to $360 with free shipping usually. That ain't bad.... I have 4 of 'em. It's the only one I have multiples of and the first one I paid full price for; it was worth it!
Mike
#275
RE: New DLE 35
ORIGINAL: rcguy59
Airborne2.4: It's being looked at. That's all I can say for now.
