Evolution/MVVS 80cc Starting Backwards!
OK, during initial break-in in my back yard, and now at the flying field for my Maiden flight on Hangar 9 SU26 MM SE, the Evolution engine started and ran backwards on me for about 2 seconds of Horror. A real surprise and shocker, but it did. I am hand flipping it and have not experienced this before but it is scary. After it did it I had a guy hold my plane but most times it started in the right direction, just that 1 in 10 times it seems to run backwards for 1-3 seconds then die.
Is there anything I am doing that may contribute to this condition? I expect and hope to see a comment from PE on this one as he seems to the be resident expert on these engines.
I also must comment, the engine is very strong. Not broken in yet but the power is unbelievable and the smoothness of the transition and the lack of vibration for such a big single is impressing me. Very high quality engine. I expect to get many great years of high performance from this unit.
RE: Evolution/MVVS 80cc Starting Backwards!
Check the timing, sounds like it is retarded, I don't know what ignition the MVVS uses but expect that it is a Valach similar to ZDZ. If that is the case 5 degrees before would be close.
It is a different ignition than Rxcel and CH etc. It has a two magnet pickup system, so it is probably more accurate than using a single magnet. Its definately more tight of a setup than other ignition setups I have seen. Thanks for the post, but I doubt that is a contributor to this issue but I will keep it in mind and check it later if nobody else comes up with anythign.
I was wondering if too much choke excess fuel or not enough choke etc. would be a factor.
Too much choke in my experience. Mine has auto-choke servo installed and it does it sometimes.
MVVS ICU ignitions have auto shutdown in case of running backwards, so there is nothing to be scared of.
ORIGINAL: Kema
Well that is very comforting to know, I did not know that but it explains why it stops after about a second each time. I may recall having read that in the manual a long time ago when I built the plane. Thanks I feel better now. I will take advice above and crack the throttle a little more so it doesnt happen as much.
THanks much.
[8D] One other small point ..........
When hand starting an engine , the speed and strength with which you flip the prop are important !
I'll not get into the whole debate over wether it's best to flip it in the normal running direction or to bump it backwards against the compression , as some recommend . But I know that the more "smartly" or "strongly" you flip the prop , the more likely it is to start in the proper direction .
You know, I never tried starting a spark ignition gas engine in reverse to get it going forward like I do with my bigger glow engines. But it might be worth a try. I have a couple of big glow engines that like doing that, and flipping them in reverse solves the problem. But yeah a little too much choke can cause it too.
Update its happening less now that I am used to it more getting more broken in and opening the throttle a little bit more on starting. Thanks guys. And this engine......unbelievable power its sick. Pulling my 24 pound Sukhoi vertical like a rocket. The vertical performance is sick.
