NGH 38CC 4 stroke
Old 12-12-2012, 09:38 PM
  #76
Default RE: NGH 38CC 4 stroke
Michaelchow,
Do you have plans at all to offer a muffler for this engine, and where can we get parts if needed?
Thanks in advance, Mark.
Old 12-12-2012, 10:52 PM
  #77
<span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Mr. Mark, do you mean there is no muffler in GF38 box? each GF38 has a muffler inside engine box. please check.</span>
Old 12-12-2012, 11:03 PM
  #78
SJN
Hi Michael, there is no muffler in my box either, only the 55 degree exhaust header pipe.
Old 12-12-2012, 11:08 PM
  #79
SJN
you need to make something like this for the NGH 38cc
Old 12-13-2012, 12:30 AM
  #80
<span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Mr. Johannesen, thanks for your advice. I will try to make the beauty in picture for GF28cc future. current GF38 is just with </span> simple <span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">exhaust header pipe, but I will make some new, just afraid vibrating will effect long pipe. so need your more  professional suggestions. thank you. michael </span>
Old 12-13-2012, 08:39 AM
  #81
vertical grimmace's Avatar
How does this engine sound with the straight pipe? Are the DB too high?
Old 12-13-2012, 10:13 AM
  #82
SJN
Fired it up twice for a few seconds just to make sure it runs before taking it out to the field for break in.
It was quite difficult to prime the carb for the first time, and it did not want to draw fuel.
I had to cap off the vent line that is under the cam shaft, so a pressure pulse could reach the carb, to make it pump.
I also pressurized my tank, to push fuel into the carb.
But after that, it seems to draw fuel just fine, and I could remove the cap on the vent line.
It ran realy rough, but I expeced that since it has no run time on it.
Once, it kicked back, and loosened my prop nut, so it had to b re-tightned.
Running it in my 27% cap232 with out the wings on to dampen the vibration it brutal
It realy kicks hard at the moment, and shakes my airframe. Wings on next time.
Im quite sure I wil lhave to buy a muffler for it, as the sound level seems quite high......will have to see when I get it outside.........in the snow [:@]
ID:	1829577   Click image for larger version
ID:	1829578   Click image for larger version
Old 12-13-2012, 01:04 PM
  #83
SJN
Found another youtube video:
http://www.youtube.com/watch?v=6w53WABuoXQ
16x8 8050rpm
18x8 7300rpm
Old 12-13-2012, 01:46 PM
  #84
SJN
And a flight video from Norway
http://www.youtube.com/watch?v=XvAUa...layer_embedded
Old 12-13-2012, 06:49 PM
  #85
Sonnich,
Your engine will get better with more time. Mine is running pretty good now that it has about 1.5 hours on it. This engine is a fuel miser, you can use a real small tank in the plane. Mine now will run about 30-45 min. on 6oz. at very fast idle and full throttle runs. It also runs much smoother on less oil in the fuel...28-1.
I'm thinking about getting a Saito 220/fg36 muffler to put on mine, it's a little too loud for our field with a straight pipe only.
Still haven't got an answer from Michael about parts yet. So far there doesn't seem to be very many of us running/flying these engines yet. There MIGHT be an issue with the aluminum header stress cracking at the flange.....just thinking.
Mark.
Old 12-13-2012, 07:46 PM
  #86
<span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">Mr.Mark,sorry for </span>Late response. Parts supply for four stroke is very important, so it is most important for me consider parts supply smoothly.  dealers will soon inventory parts, we ensure original made parts and very easy to get parts. so please contact dealer you bought from and send a request, dealers will service you No matter whether you bought from him. and let me know result please. thank you very much, michael
Old 12-13-2012, 08:02 PM
  #87
moreover, please pay attention. different prop and oil will get different output data on same engine. someone prefer smaller size prop to get bigger tension even use 16*8 Three-bladed propeller. we always use 20*8 wood prop, normal output is at about 6000rpm, If your engine speed far lower from 6000rpm, Please consider you use prop and  oil, please use higher grade 100% complete synthesis oil. thanks
Old 12-13-2012, 09:15 PM
  #88
Turk1's Avatar
Hi Michael, when new batch of engine will be on sale again?
Old 12-13-2012, 09:35 PM
  #89
Mr.Turk1<span style="font-family: tahoma, verdana, arial; background-color: rgb(251, 252, 255); "> , </span>Do GF38 really a little difficult, And the number of each batch is not much, We'll have a lot of work to do. A batch of goods will be sold in the next week, but has set out. This lot of goods to the main supply to Europe Just engines/modelpascher and himodel,taiwan, and Christian Traders Australia. thank you. <div>
</div><div><span style="color: rgb(31, 73, 125); font-family: Calibri, sans-serif; font-size: 15px; line-height: 25px; ">Christmas</span> is coming, best wishes for you all!</div><div>
</div><div><font color="#ff0000">MERRY CHRISTMAS</font>!<div>
</div></div>
Old 12-14-2012, 01:22 AM
  #90
I like your 4 stroke very much !!
Do you have plans to make twin four stroke !
Very interested !!
Merry Christmas
Old 12-14-2012, 07:16 AM
  #91
Can anybody tell me if AMR stocks the latest version of this for stroke 38 gasser
Old 12-14-2012, 07:24 AM
  #92
SJN
Since this engine only has been around for a few weeks now, it will be the same as the ones in this thread
Old 12-15-2012, 05:26 AM
  #93
earlwb's Avatar
I was thinking that the ASP 1.80 four stroke engine's exhaust and or muffler would fit this engine. Both engines are, more or less, look a lot alike. At least the muffler itself might be useable.
Old 12-15-2012, 09:17 AM
  #94
jeffEE's Avatar
AMR, thats where I ordered my motor from last week. I still have not got it in the mail yet, but that is not AMR's fault. It has been sitting in New York for the last 5 days. Must be the Xmas rush in the mail room. But according to the mail tracking site, it is on its way to a local mail center.
I was thinking about the muffler set up also. I have a saito 2.20 four stroke, and I will see if the muffler can be fitted. And if it can fit, will it help the noise level. I will let you know.
Old 12-15-2012, 09:24 AM
  #95
SJN
Looking forward to hearing your results with mufflers.
The ASP/Magnum 180 muffler looks a bit restrictiv to me, as the outlet is fairly small.
One would have to weld a threaded pipe to a flange to bolt onto the side of the engine.
Installing a piece of silicone on the exhaust header, takes the sharp pitched noise a bit......but it is still loud.
Old 12-16-2012, 06:26 AM
  #96
jeffEE's Avatar
how well does the silicone hold up to the heat? I would like to route mine to a more scale location, but was affraid the silicone would not stand the abuse.
Old 12-16-2012, 01:38 PM
  #97
My Feedback: (8)
rcguy59's Avatar
Silicone Should NOT be used with petroleum-based fuel. The fuel and it's residules will destroy the silicone pretty quickly. Use Teflon (PTFE) instead. It holds up much longer.
Old 12-16-2012, 05:56 PM
  #98
Ernie Misner's Avatar
Where are you getting the Teflon tubing Mike?
Old 12-16-2012, 06:07 PM
  #99
http://www.youtube.com/watch?feature...&v=PBFwA0OSP1M
Troy Built Models silencer
Old 12-16-2012, 06:24 PM
  #100
My Feedback: (8)
rcguy59's Avatar
It can be found online, Ernie. It's seldom cheap, but it's gas-proof and resists VERY high temps. Perfect for exhaust use.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
