NGH 38CC 4 stroke
Old 12-19-2015, 07:35 PM
  #1351
Oh! Well that makes perfect sense then.
Old 12-19-2015, 07:40 PM
  #1352
I have this engine in an ESM Corsair and a Greatplanes Waco. Wingspan about 72-74 inches. I know of one in an ESM Val and a Storch. Probably ideal for 70-76 inch wingspan 16-20 lb models. OT is a little big for the Waco, but not indecently so.
Other contributors might have other ideas.
Old 12-20-2015, 02:03 AM
  #1353
My Feedback: (22)
I also have my 38 in the Waco and it fit great and hauls the plane around quite well. I have always wanted a Storch so I will see if I can find one. Thanks!
Old 12-20-2015, 04:59 AM
  #1354
My Feedback: (22)
Storch not available any more.
Old 12-20-2015, 09:23 PM
  #1355
Shame about the Storch! I won't be buying another ESM Corsair either! The flaps are an absolute PITA and the ARF was missing some hardware.
It's a pity about ESM. Can't buy in my part of the world, freight from USA is stupidly expensive and the kit is missing bits!!!
No, I won't go down that road again!!
Old 12-20-2015, 09:25 PM
  #1356
What about "Blackhorse " models? I can't get them either, but maybe you can. They look quite good.
Old 12-20-2015, 09:41 PM
  #1357
w1nd6urfa's Avatar
NGH 38cc in an ESM Storch?
I had trouble fitting a front carb MVVS 26cc in that tiny cowl, i wonder what the 38cc looks like
Old 12-20-2015, 09:44 PM
  #1358
No . Not an ESM I think. I believe Tyor has a 38 in a Blackhorse Storch. I could be wrong, there is video of his model flying if you search this thread.
Old 12-20-2015, 09:55 PM
  #1359
Post#409 Page 17 of this thread.
Old 12-21-2015, 03:25 AM
  #1360
My Feedback: (22)
Watched the video! What a nice plane. I really want one now. I will look for BH version. I think a place called Hobby People in California carries BH models. Thanks for finding that post!
P.S. I have a friend at the field that has the giant esm corsair and had the same issues. He also thought it was a bit heavy, but has a DA60 in it and it flys well.
Old 12-24-2015, 08:02 AM
  #1361
About to complete the tank installation in my Tiger Moth which will have the GF-38 inverted. Can anyone please advise the optimum height in relation to say the crank center line.
Old 12-24-2015, 08:28 AM
  #1362
SrTelemaster150's Avatar
It doesn't matter so much with "gas" engines since the carburetors have diaphragm pumps & regulators.
Old 12-24-2015, 08:55 AM
  #1363
Thanks, was a bit worried that the carb may flood as the tank center line is currently above the height of the fuel inlet.
Old 12-25-2015, 04:14 PM
  #1364
So..... after a 6 month wait whilst I tracked down a replacement wing ( had to buy a complete arf kit ) for my ESM Corsair I finally brought her back to the field.
New spark plug, started second spin of the starter, minor tune for the hot conditions of the day and away we go!
The GF 38 ran really well!!
Old 12-27-2015, 04:04 PM
  #1365
How has these motors been holding up? I thinking of getting another one for a Great Planes Avistar GP/EP
My old one ran very reliable but shacked a lot. Are you guys breaking any parts like mount or manifolds have the airframes holding up like the fire wall and stuff. Just if they could make a cheap twin.
Old 12-27-2015, 04:07 PM
  #1366
My motor started and ran on 2 flips by hand I thought it was easy but was on the bench and it did spit a lot of fuel too
Old 12-27-2015, 04:24 PM
  #1367
Haven't broken an engine mount, firewall, or manifold..
....yet!
Old 12-29-2015, 11:43 AM
  #1368
tyor's Avatar
I have mountet one of my 38cc in a pilot-rc 25% sbach. Interesting to try a 4-stroke in that kind of plane. checked cg without the ignition module end the ignition battery in the plane. and it was a little tail heavy, so putting the module and battery up in front will fix that
Old 12-29-2015, 12:37 PM
  #1369
Looks good Tyor!
I had an interesting morning with my corsair 38 yesterday. Was tuning when the engine began to misfire. It then stopped and when I turned it over by hand there was almost no compression!
So I thought I'd check the valve rockers, the whole rocker arm rod was loose!! The hex screw that holds it had vibrated loose!!
Tightened up and re-checked clearances. Ran it. Runs good!!
Phew!!!!
Old 12-29-2015, 12:50 PM
  #1370
My engine was acquired from a club member who had it mounted in this type of model. It flew OK, but rattled and shook plenty and we reckoned the chaff-cutter sound was all wrong for this plane.
I intend to mount it in my 90" Eindecker which is currently a little underpowered with an old Zenoah G-26. One more project on the ten-year plan .....
Alan W
Name:	Eindecker 5 - 27 May 2010.jpg
Old 12-29-2015, 12:59 PM
  #1371
tyor's Avatar
I think the engine wil be ok in the eindecker I have only 4 stroke engines in my planes now and no more glow engines so if the sbach dont work with the ngh I maybe try a saito gas. I have 2 saito radial engines. one fg19 and one fg84. Both run perfect. here are a video of the fg19 in a hangar9 sopwith camel.
https://www.youtube.com/watch?v=RY_pToj5IuE
Old 12-30-2015, 11:09 AM
  #1372
who is 90" Eindecker kit by
Old 12-30-2015, 12:31 PM
  #1373
tyor's Avatar
started de engine in the plane today. got 7200rpm on 18x8 and 6100rpm on 20x8 so I will try the 20x8 prop. it will giv more thrust and the engine is alot smoother with a biger prop. Think I will maiden on saturday.
Old 12-30-2015, 07:27 PM
  #1374
How is the vibration are they still shakers after they are broke. in.
Old 01-06-2016, 04:41 AM
  #1375
My Feedback: (47)
MYHELL99's Avatar
Default Soft Mount
I've decided to try installing this engine using the DUBRO 1.20 soft mount. I needed to modify one of the mount rails by filing it at an angle to clear the carb. I also filed down some of the choke control arm material to also give me some clearance. I hope this works!
-Richie
ID:	2139942   Click image for larger version
ID:	2139943   Click image for larger version
ID:	2139944   Click image for larger version
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
