NGH 38CC 4 stroke
Old 01-06-2016, 05:51 AM
  #1376
DoctorG's Avatar
Interesting to see how that works. I've never had much success with soft mounts on gas engines.
Old 01-06-2016, 03:57 PM
  #1377
My Feedback: (22)
Decided to try the ngh 38 in a seagull spitfire. The firewall will need cut back about 30 mm, but it should work well. The plane looks really nice, my only gripe is that the flaps are warped.
Can anybody tell me what post or posts cover the mods that are needed on the ngh38 to reduce oil leakage, etc.
thanks, Bob
Old 01-06-2016, 05:08 PM
  #1378
SrTelemaster150's Avatar
Originally Posted by MYHELL99
I've decided to try installing this engine using the DUBRO 1.20 soft mount. I needed to modify one of the mount rails by filing it at an angle to clear the carb. I also filed down some of the choke control arm material to also give me some clearance. I hope this works!
-Richie
You can make any mount "soft" by substituting "well nuts" for "T" nuts in the firewall. I use a nylock nut on the back to lock it in at whatever resilience wanted.
You ca get them at any well stocked traditional hardware store for less than $5.00 for all the components needed.
Old 01-07-2016, 08:26 AM
  #1379
My Feedback: (47)
MYHELL99's Avatar
I do like your suggestion! I'll keep that in mind on any future needs, since I'm already invested in the DuBro mount path now.
-Richie
Old 01-24-2016, 09:48 AM
  #1380
flycolorado's Avatar
Edit...
Old 02-10-2016, 07:18 PM
  #1381
Well, I had the first failure of an NGH 38 the other day. Took both my Waco and ESM Corsair to the field. The NGH 38 on the Waco performed flawlessly. Launched the Corsair, flew about 5 circuits a few loops and rolls and then there was a horrible grinding noise coming from the aircraft accompanied by a loss of rpm and power. I managed to get the gear down and flaps positioned for a landing, 100 m out from the strip the engine stopped. Brought the model in on a fairly good profile for landing, but bounced and had no power available to recover. Flipped over, some damage to undercarriage, rudder and elevator. Worst thing is a tear in the fibreglass skin of the wing in the area I have found to be most prone to weakness and stress. This was my new wing that took me months to procure at great expense!!!
Well, it is repairable, but probably never be as good as new. More of a concern is the engine. Am going to strip it down soon and see what there is to see.
Flew the Waco afterwards and it was a reliable trouble free flight!!
Old 02-13-2016, 04:24 AM
  #1382
DoctorG's Avatar
Default Ugly Stik Test Bed
Actually got some airtime in with the NGH38 fitted to my scratch built 80inch Ugly Stik. Since I bought this engine back in April last year it has managed a couple of minutes in my aborted Stampe, and one flight in the Ugly Stick before the tailplane came off (!) and engine had to be dug out off the Hampshire country side. Since the rebuild of the Stik last November the weather in the UK has been relentlessly wet and windy so hardly any flying at all.
Anyway it has still only hauled the Stik around for a half dozen 10 minute flights so about 1 hours air time but so far hasn't missed a beat (even after it's interment) so still early days but I am very happy with it so far.
The plan is to run it in the Stik until the new Stampe is finished and then I transfer it so I won't be having a new model and untried engine combination.
Onwards and upwards
Name:	Dog & Stik.jpg
Old 02-13-2016, 05:12 PM
  #1383
Onwards and upwards
Nice dog there Doc . Very fond of the old labs . Heres some pics of ours if u look down the page a bit . cheers
http://www.rcgroups.com/forums/showt...34187&page=123
Old 02-14-2016, 09:37 AM
  #1384
DoctorG's Avatar
At the risk of hijacking this thread to talk about dogs I don't think mine would appreciate being called old - he was only 15 months when the picture was taken . I will say no more about dogs I promise.
Old 02-14-2016, 03:17 PM
  #1385
Well then if he's only that old , it looks like he's got that evil look in his eye and ready to take a bite of the tail plane . Cheers
Old 02-16-2016, 06:44 AM
  #1386
Very good Idea....things like this really help ! John
Old 02-16-2016, 07:15 AM
  #1387
raptureboy's Avatar
Just make sure you check them for break down if using nitro fuel as the residue will breakdown the rubber. If you can find silicone ones it would be better.
Old 02-19-2016, 06:35 PM
  #1388
I will use them on a gas set-up. I do use silicone spray on most rubber products with very good results !
Old 02-22-2016, 02:30 PM
  #1389
So... I stripped down my mis-behaving engine. I expected to find something obvious, but no smoking gun to explain the screeching sounds, loss of power and eventual stoppage. Bearings look o.k, no debris in the engine. Everything appears to be well lubricated. Only thing I have found is a few score marks in the piston sleeve. Possibly made by the ends of the piston rings although they seem to have a tapered end to them to avoid such scratching.
I will replace the bearings (because I've got some), probably replace the sleeve (if I can get one) and put it back together.
We'll see......
Old 02-22-2016, 02:52 PM
  #1390
O.K..... scrap that idea. Don't seem to be able to buy a new sleeve. Will use old sleeve or scrap engine altogether.
Old 02-22-2016, 09:10 PM
  #1391
sounds like she may of gotten lean.
Old 02-23-2016, 10:13 AM
  #1392
Yeah, possible I guess, although it did not seize and there is no evidence of overheating. It's almost as if the scoring in the barrel has been caused by debris entering the combustion chamber/barrel. Not all that surprising given there is no intake screen or filter. I know it would restrict airflow, maybe a screen would be o.k.
Real shame I can't get a new sleeve. You'd think, of all the spare parts you would stock and supply a sleeve would be high on the priority list. Not so with NGH and their pathetic little list of distributors.
Well... I'm going to try to hone out the sleeve and see what happens.
Old 02-23-2016, 12:41 PM
  #1393
Oh.... just found the spares at Just Engines in the U.K. Maybe a little expensive, but they do stock a good range of parts including the sleeve!!! I'm on to it!!
Old 02-29-2016, 03:35 AM
  #1394
only if they could make a 60cc twin 4 cycle at a nice price.
Old 04-03-2016, 08:24 PM
  #1395
Well, new front and rear bearings, new cylinder sleeve, new piston rings. Started up just fine, run in as per new engine, now making full power and idling o.k. Am pretty happy with it, just have to decide whether I trust it in a new model. I think I will....
Old 04-04-2016, 09:49 AM
  #1396
This engine is way too much trouble. After 1 year of building a great scale P-40 and breaking this engine nicely and having it perfectly tuned it couldn't even generate enough power to get a 15lb model off the ground. The plane just went up for a second and turned and crashed. Just too little power. I was using a 3 blade prop maybe I should switch to a 2 bladed 16 x 8 wooden one.
Old 04-04-2016, 11:28 AM
  #1397
Hey Basil, I am surprised it wouldn't fly a 15lb model. I am flying a 72" wingspan Waco no problems, and the engine does fly my 20lb 74" wingspan corsair with adequate power, both on XOAR 18 X 8 2- blade propellors. I did try to fly the corsair on a 3-blade propeller, it wasn't great.
Definitely 2-blade for me!!!
Old 04-05-2016, 11:43 AM
  #1398
Going to put it on a Blackhorse Fieseler Storch.
Old 04-06-2016, 09:55 PM
  #1399
I ordered another one. I hope it ran as good as the 1st one. But not sure long term if it will vibrate apart. They need to get rid of the blue parts and just keep it silver.
Old 04-08-2016, 12:16 PM
  #1400
wonder if there is any quality issues between hobyking and the others that sell it like hobbyking will sell the motors with rejected parts and sell cheaper.The one I had that ran good was from AMR.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
