NGH 38CC 4 stroke
Old 01-31-2013, 04:17 PM
  #176
My Feedback: (149)
Default RE: NGH 38CC 4 stroke
Mike,
see post 169 where a Saito muffler was installed . . . . apparently only run for a short. Mabey SJN will respond here
T-man49
Old 01-31-2013, 08:59 PM
  #177
SJN
It sounded fine when running, but I can not tell if it sounded like a Saito. :-)
If you can afford it, then buy the saito.
Old 02-01-2013, 10:42 AM
  #178
jeffEE's Avatar
I just got a return note from the folks at AMR where I bought my motor. I think this is a good company to deal with. My qusetions were answered with out any bull or run around. Gotta like that.
Old 02-02-2013, 04:43 PM
  #179
Hey Guys,<div></div><div>if you are looking for a muffler, maybe this could help: http://www.modellmotoren.homepage.t-online.de</div><div></div><div>Armin is well known here in Germany for building 4 Stroke Engines. He has a muffler for his 38cc VT 38 Engine! Maybe it also fits on the NGH header.</div><div></div><div>Click on "Motoren" then scroll down and click on "Zubeh&ouml;r" or switch to the english version (but i don't know if the english version is on a current status)</div><div></div><div></div><div>Christian</div>
Old 02-08-2013, 08:30 PM
  #180
Now after the first day of flying with this engine, three flights, Iv'e found the crank has alot of play at the bottom end of the rod. This isn't good. I won't dump any more cash into this POS. Lesson learned.
Mark.
Old 02-08-2013, 09:36 PM
  #181
3136's Avatar
ORIGINAL: MKnutson
Mark.
Are you sayingthe crankhad littleplay before you used it and now after 3 flights it now has a lot of play?
Old 02-08-2013, 10:21 PM
  #182
Turk1's Avatar
How did you check this? It seems it cant be possible a needle bearing to loose after several hours run without throwing a needle.
Pls. detail the problem you feel.
Old 02-08-2013, 10:42 PM
  #183
First off, it's not after several hours, but maybe an hour total time.
It had very little play if any at first, now it has way more than I feel safe running with.
Iv'e got a 15 year old Brison 3.2 here that's never been apart and still runs like a top, and tight.
It can be possible due to poor quality material in the crank pin and bearing. All you have to do to check it is to rock the crank lightly back and forth with the crank pin 90 deg. to the cyl., or halfway down the stroke. This should not have any play with a four stroke, a two stroke not quite as critical since the rod is positivly loaded all the time.
Mark
Old 02-10-2013, 06:16 AM
  #184
earlwb's Avatar
Sounds like the bearings may be defective. But I don't know if that is indicative of all of the engines though. I have seen unlucky guys with major brand name engines having bad bearings in them too. The major brand names are supposed to be ultra high quality no less, but they still had bad bearings show up from time to time.  It does suck to have to repair the engine after such a short time, but it is good you caught it before a bearing comes apart and shot peens the insides of the engine.  It is interesting, we'll have to watch and see if anyone else has the same problem or not too.
Old 02-10-2013, 08:09 AM
  #185
Neo gold's Avatar
Hmm, i was always sceptical over the NGH range...&amp; tbh with the amount of flying i do...i sold all my Gassers &amp; actually went back to glow..for that unmistakable sweet awesome 4-stroke glow rumble, esp for my ESM warbirds!...i run SC engines now &amp; the 180 on an 18x8 prop uses very little fuel &amp; has never missed a beat!!..cheap 4-stroke glow for the win!.
Old 02-10-2013, 08:41 AM
  #186
SJN
Mark, how much play have you got ?
Here`s mine :
http://www.youtube.com/watch?v=W2NDl...ature=youtu.be
[youtube]http://www.youtube.com/watch?v=W2NDlTCkUyE&list=UUm87T1DR5SdALQ-2tuK4s-A&index=1[/youtube]
Old 02-10-2013, 10:30 AM
  #187
Neo gold's Avatar
Hey...that's not a problem, i see only lateral play in your video...up/down movement would be a problem though...
All i see there...if you can imagine the piston in the bore/ &amp; the ring is sat in the bore...that movement is the play in the ring land!....looks ok to me.
Old 02-10-2013, 10:39 AM
  #188
SJN
Yea, mine is fine, but would like to compare it to Mark`s :-)
But Mine hs only been run for 2 minutes max....so lets see
Old 02-10-2013, 09:30 PM
  #189
If your ring lands and grooves have that much play there's a problem, that thing will hammer itself apart in no time!
SJN, mine is like yours in the video. The movement at the end of an 18in. prop is about 3mm.
I'm comparing to my other engines: new DLE35RA, DLE20, OLD Brison 3.2, G62, g23 and a g26, all of which are tight...NO play.
Mark
Old 02-10-2013, 10:39 PM
  #190
3136's Avatar
Hey Mark if you really think it's a POS I'll give you $100 for it (plus postage)
Old 02-11-2013, 07:07 PM
  #191
I think I'll keep it and run it till it blows, maybe it won't, we'll see.
Old 02-14-2013, 08:00 AM
  #192
SJN
Saw this video of it powering a 50cc 2 stroke p-51 mustang airframe.
18x8 prop.
Seems to power it allright in a scale manner concidering it is a fairly large plane for the engine
[youtube]http://www.youtube.com/watch?v=i2HCdUgmy8w&feature=player_embedded[/youtube]
Old 02-14-2013, 09:51 AM
  #193
SrTelemaster150's Avatar
ORIGINAL: SJN
Saw this video of the it powering a 50cc 2 stroke p-51 mustang airframe.
18x8 prop.
In the text, the video poster claims 7100 RPM W/an 18 X 8 prop. That is pretty weak, about 2HP.
My FA 150 CDI running on E-85 made 7500 RPM or about 2.4HP W/an 18 X 8. Later I found out that in winter, Northern states E-85 mix is closer to E-60 as they up the percentage of gasoline for better cold weather starting. (I bought the fuel in New York state in the Syracuse area @ the end of February last year) I doubt that straight gasoline would have dropped the power as low as 2HP. That's a 25cc 4-stroke engine, 35% smaller in displacement making as much or more HP..
I just don't see the idea of running a large/heavy engine that makes so little power.
If price trumps performance, then I guess it makes sense.
Old 02-14-2013, 01:28 PM
  #194
ORIGINAL: SrTelemaster150
ORIGINAL: SJN
18x8 prop.
Did we watch the same video? I saw a large warbirds that while not overpowered looked ok. This on a 38cc four stroke. I learned a couple years back from some engine guys that used to post on here all the time, stop worrying about RPMs and start looking at thrust and how the plane flies. RPM is useless if the plane does not perform. Just my 2cents.
Old 02-14-2013, 03:28 PM
  #195
ORIGINAL: skillet92
ORIGINAL: SJN
18x8 prop.
All that video proves is that the combo is marginal under the most ideal flight conditions.
RPM W/a given prop = thrust. More RPM W/that prop = more thrust.
An 18 X 8 @ 7100 RPM = 15.48# of static thust @ 32° F. At 86°F that same 7100 RPM would be decreased to 13.95#, but @ 86° the engine would not make near as much power (RPM) so thrust would be decreased even more dramatically.
I used 32°F since the video was obviously shot @ low temperatures as evidenced by the snow. On a hot, humid August afternoon in Southern Indiana that plane would not be performing nearly as well as it did under the nearly ideal low DA conditions in the clip. If it did get off the ground, it would be flying on the verge of a stall. Low DA (cold, dry, dense air @ high barometric pressure) = more power & more lift. High DA (hot, humid air) = less power & less lift.
My converted FA150 CDI engine would be considerably lighter while producing 20% more HP & 17.28# of static thrust. I would not even consider putting my FA 150 CDI into a 50cc sized airframe.
Old 02-14-2013, 05:15 PM
  #196
Depends on the airframe. I have an ESM corsair 74" wing that I fly on a g-38 Ralph converted 18x8 xoar. I also have a ESM fw190 with a dle 30 that is also turning a 18x8 xoar. Both fly well. While the FW flys with more punch the corsair still flys well and it needed the weight of the g-38 up front. I fly at sea level and in the south with our heat and humidity. I don't have this engine but i am looking at it and I don't go by numbers and figuring. I go by what a said nine will do in a certain plane or prop. I need to see more on it to tell wither it will work with a warbird or two. I figure all my planes separate depending on hat I need for each on based on weight and power. A lot of extra weight mounted up front create other problems.
Old 02-14-2013, 08:17 PM
  #197
Nice break-in run....Hard and fast,seat the ring quick! That's how I do it too, don't have a bad runner yet, all have excellent compression.
You notice in the video that the power is at full boil the whole time? It could use a little more power.
Mine was turning a 19-8 xoar at about 6600 at 100ft base elev., not real strong.
Mark.
Old 02-14-2013, 09:13 PM
  #198
Turk1's Avatar
Gents all you forgot is all those are still brand new,2 ringed  and steel linered engines.That means they need quite hours to break in(both rings and also liner will match unlike hardened alu.blocks).Those power figures will improve then.8-10 kgs P51 flies very well on video.I want to see it after 10-15 hours flight .
Old 02-14-2013, 09:18 PM
  #199
3136's Avatar
It would be interesting to see one with Bowman rings.
Has anyone tried a 18x10?
Old 02-15-2013, 03:42 AM
  #200
ORIGINAL: Turk1
It would be interesting to see it fly on a hot summer day.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
