3w 106
Old 09-13-2003, 08:55 AM
Mark Bowman
Default 3w 106
I have 3w 106 AI have about 50 flights on motor runs great have not changed the setting since the first few flights running 3w 27x10 about 6000 rpms the only thing that has changed is when I taxi out down the runway the motor seems to load up a little but once it in the air for a few seconds its fine just afraid of the motor quiting on take off
Old 09-13-2003, 11:23 AM
JB Rekit
JB Rekit's Avatar
Default RE: 3w 106
your low end is rich and is pooling up gas in the carb (loading up) when the engine idles. Just lean it out about 1/8 turn at a time, maybe more on your first turn if it is as bad as you say it is. Then check your top end again to make sure it is ok since the bottom can change the top.
John
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
