Oil spatter
Hi All,
Please see accompanying picture. I am curious what you think the cause is and how to remedy the excessive oil spatter.
The oil is mixed at 50:1 and is a fully synthetic type. The engine has about twelve hours total operation time.
The engine makes awesome power at top end, idles nice and transitions well in the air. It hesitates slightly on the takeoff roll but after that no further problems. The plugs show dark tan in color as if slightly rich.
Paul
Paul
I agree with w8ye. I have dles, zenoahs, and mvvs engines that have way less run time and I use 32-1 penzoil. I don't have no where near that kind of oil residue. I would add a down pipe to the exhaust to get it a little more in the airstream away from the plane.
What engine is it ?
Most of my engines run 40:1 and I only get a few specks on some and slight splatter on one that is still breaking in.
I have the Evolution 10CC engine and that thing runs 20:1 and has tons of residue during break-in and supposedly it takes a long time for it to lessen.
Make sure it's not running too rich and as mentioned ,use and exhaust extension/diverter.
This is a question, not a solution, sorry. Is there a wax or something that can be applied to the area that acculates spatter that would makle the spatters more easily removed? Thanks.
My Feedback: (35)
KY
I've been flying gas for a long time and have been around DA too. I have never seen a DA do that. You said that it misses on take off. That tells me the engine is rich on the low end. The mess you have may be when the engine clears out on take off. When the engine clears out it will blow a lot of raw fuel and oil out. Dennis
My Feedback: (117)
Peter Goldsmith flys a DA 100 in his big Pawnee. It has a lot of gas/oil residue on it. Worse than the original poster. W8YE gave him good advise...Maybe it is some other DA's your thinking about??
Brian
ORIGINAL: DadsToysBG
ORIGINAL: airtourer
Hi All,
Paul
Hi All,
Paul
It's a little odd how DA USA say to use amsoil and DA Australia say to use redline.
http://www.desertaircraft.com.au/sho...or-da-engines/
I agree with everything that has been posted here. One other thing I would look for is a loose bolt holding the engine down, at the muffler, or anywhere else in the engine area. If a bolt is vibrating even a little, or the muffler is loose, the vibrating turns the oil very dark and looks like this. I know, I've seen it on my models...
Worth a look..
Worth a look..
