which is best 26-35cc engine?
Old 07-30-2013, 03:17 PM
IMAC781
IMAC781's Avatar
Default RE: which is best 26-35cc engine?
Sorry CK1 I meant to reply to MTK.
Old 07-30-2013, 05:11 PM
Ernie Misner
Ernie Misner's Avatar
BTW, the ad for the new RCG 26 beam mount engine is in the latest AMA mag. BP hobbies sell them I think it said. 32 oz. all up weight, sounds good since the 20cc's are 29oz AUW if I remember right.
Old 07-30-2013, 08:10 PM
Indiomike
Indiomike's Avatar
Generally speaking, I think the quality and care in the making of O S engines is excellent. However, I will give 3 reasons why I won't buy the GT 33 model.
1. Price. Way too high IMO.
2. Tendency to run backwards when hand started. I think O S made a comment about this, saying they designed their engines to be started by an electric starter which provides greater torque and starting rpm than a hand flip can provide. I agree that is true and safer than hand flipping but I prefer to hand start my gassers as I believe the majority of gas engine guys do. A matter of personal choice.
3. The prop shaft on the GT 33 is 8mm. An engine this size usually requires at least an 18 inch prop. Almost all props of 17 inch or greater comes factory drilled at 10mm. You therefore need a bushing of some sort to properly center the prop on the shaft. O S should have made the prop shaft at 10mm.
Whether you find these 3 things picky or not makes no difference to me. They are the reasons I won't buy one. I'm not saying O S doesn't make a good engine, as I am sure they do. I just find these things cause me to look at other brands in this power range.
Mike
Old 07-30-2013, 08:44 PM
Ernie Misner
Any clue why this OS is more prone to run backwards?
Old 07-31-2013, 04:03 AM
guille2006
guille2006's Avatar
I can't be happier with my mintor 33... easy start; great price and specially great looking!!!
Old 07-31-2013, 04:49 AM
  #31
BarracudaHockey
BarracudaHockey's Avatar
Mintor's have a dubious rep over here in the states.
Mike is dead on about the OS, its a very nice engine but it's not cheap and unless you run APC props it will need a shim.
As for starting I can get it to hand start most of the time if you give it 1/4 throttle or so and flip it briskly.
Old 07-31-2013, 04:53 AM
  #32
gwweber
My Feedback: (24)
Go with the dle    cheap and have a good service if you buy throught troy built models.   I usually run either a da or dle.  I have a da120   it is a beast,  I run a dle55 in my aerobat and have two years on it.  Starts real easy and runs great.  I have had issues with a dle 30, but have also had issues sith a da60.  Service is very good on both of those however.  I guess the big difference is supposed to be htat the da engins last longer, perhaps better bearings.   How many people have engins that outlast the airframes anyways   LOL
Old 07-31-2013, 05:49 AM
  #33
IMAC781
IMAC781's Avatar
As you say okdreamin, the Fairchild is coming in heavy. I will probably use an engine with a weight that allows cabin mount for elevator servos.
Old 07-31-2013, 06:15 AM
  #34
MTK
ORIGINAL: Ernie Misner
Ernie,
The OS hand starts backwards sometimes, when throttle setting is wayyy down. As I mentioned before, I move the throttle trim up to full and it hand starts in the right direction every time, easily. It's no big deal
As I recall, the PTE36R did the same a few times early on....None of the DLE's I've run have done that; they just start and run easily. But I've not used the standard CDI for any of my DLEs, only Bill Carpenter's CDI (a great gizmo, BTW).
Ditto for my Syssa's; simply choked'm and flipped 'm often only once....
The great thing for the OP is the fact that there are a bunch of choices any more in this size range, where 5 years ago one had only a coupleoptions available. This size rangerepresent afairly large market and I expect to see even more competition from the various sources with some very good, light, powerful, simple to operate and maintain offerings. We all benefit!!
Old 07-31-2013, 09:15 AM
  #35
Indiomike
Indiomike's Avatar
I don't know for a fact why that happens but I will take a guess. I suspect the timing is very advanced and with the relatively slow speed of a hand flip, the engine fires too soon driving it backwards. The high speed and torque of an electric starter establishes the rotation which overcomes the likelihood of kicking back the other direction.
Mike
Old 07-31-2013, 10:14 AM
  #36
BarracudaHockey
Probably. The ignition is set not to fire until the equivalent of a few hundred RPM though, so you have to give it a pretty brisk flip to begin with or the ignition won't even fire
Old 07-31-2013, 10:59 AM
  #37
acerc
acerc's Avatar
Most any 2 stroke engine can run backwards. But not with any power or throttle ability. The timing is too far after TDC (retarded) in reverse for anything other than a low idle and sporadic at that. Most times one does not fully flip the prop thru the compression stroke which causes the engine to kick back and it will kick well enough to cause the Ign to fire. Now you can move the pickup and make the engine run counter rotating.
Old 07-31-2013, 11:10 AM
  #38
Ernie Misner
I guess the ignition units don't really care whether the magnet passes the sensor in one direction or the other, will still make spark although out of time in reverse. I think the reed valved engines and piston ported engines would run equally well in reverse except for the ingnition timing. Rotary valved engines would have a problem though making any power. I don't know how they could build in a safety devise to kill the spark in reverse. It is a safety problem if the plane is restricted from moving forward only.
Old 07-31-2013, 12:35 PM
  #39
David Eichstedt
My Feedback: (17)
I'm not going to push hard on this or try to make a hard sell since I work for Horizon, but the new Evolution 33GX might be one to look at, also.
http://www.horizonhobby.com/products...ngine-EVOE33GX
Old 07-31-2013, 03:48 PM
  #40
hrrcflyer
OK,
I'll chime in on this question. IMHO, A 3W28 is a better made motor and will outperform and outlast every other motor mentioned in the responses. Yes, it is probably the most expensive, but as the old saying goes "YOU GET WHAT YOU PAY FOR". Plus, you get exceptional support and service from Gerhard at Aircraft International. Let the blasting begin........
Take care,
David
Old 07-31-2013, 06:27 PM
  #41
acerc
acerc's Avatar
One can't argue with quality of the 3W line. But for most normal everyday fliers an airframe either will not last long or be kept long. Therefore making a cheaper motor a better value. I don't mind the lesser priced engines because I am capable of my own repairs and maintenance. But then again I did just buy a 3K dollar Valach, go figure.
Old 07-31-2013, 11:49 PM
  #42
Red Baron Mike
My Feedback: (285)
Red Baron Mike's Avatar
I have a new Zenoah G-26 Magneto engine listed in the classified section for $237.00 with free shipping.
Old 07-31-2013, 11:58 PM
  #43
IMAC781
IMAC781's Avatar
The 3W28i is not completely out of the picture for my project. It looks like it has a canted exhaust port. Some users mention using a DLE muffler on the 3W28i. Do most users use a header and cannister or is a regular muffler available for the 3W28i?
Old 08-01-2013, 05:20 AM
  #44
mattnew
But its not $500 for the O.S. or the evo...
you can get the gt33 for under ~$350, the dle35 for ~$300.. you are talking about 50 bucks, not a 2x price increase.
ORIGINAL: ahicks
Matt, I get the fact 100 hours of engine time is a bunch, more than many (most?) engines will see in their lifetime. But just to provide an opposing view regarding amortized costs? Though it's hard for me to imagine wearing out my 20, if I did, I could replace it, leaving me with a brand new engine, and still saving money over the price of an OS?
An RCGF (have you seen the beam mounted 26 w/same weight and dims as the 20?) or the VV engines are even less money, and just as likely to go the distance as well?
Point being, for what you have into a 200 dollar engine, and what you can reasonably expect for it's lifetime given reasonable luck and care, spending 500 on one 20cc engine not for guys with pockets as shallow as mine are....
Old 08-01-2013, 07:11 AM
  #45
ahicks
Good point, LOL, comparing the prices of 20cc engines to 30cc+ engines isn't real fair is it! No clue what I was thinking, but the logic obviously WAY wrong. Thanks.... -Al
Old 08-06-2013, 06:23 PM
  #46
hrrcflyer
IMAC781, The 3W28 does have a canted exhaust, but I cannot help you with any information regarding the DLE exhaust. Why don't you call Gerhard at Aircraft? He will be happy to help you with your muffler questions........ Also, if you're looking for a little more oooomph than the 2.75hp of the Classic version of the 3W28, don't overlook the 3W28CS. It has 3.75hp and the shiny red cylinder won't look too shabby sticking out the bottom of the cowl.
Old 08-06-2013, 11:40 PM
  #47
IMAC781
IMAC781's Avatar
Thank you hrrcflyer. Thank all of you for your helpful input. When I have made more progress on the Fairchild LARGE SCALE RC AIRPLANE I will tell you my decision. Looks like a DLE30 w/http://us-mg205.mail.yahoo.com/neo/launch?.rand=989077373&action=inbox JTEC large wrap around Pitts muffler.
Old 08-06-2013, 11:44 PM
  #48
IMAC781
IMAC781's Avatar
Thank you hrrcflyer. Thank all of you for your helpful input. When I have made more progress on the Fairchild I will tell you my decision. Looks like a DLE30 w/JTEC large wrap around Pitts muffler.
Old 08-07-2013, 11:33 AM
  #49
Whistling Death
Whistling Death's Avatar
My DLEs have been good so far. They have been dependable for me so I think they are a good value.
I don't own one of the overpriced engines so I can't say what tier they belong in.
Old 08-07-2013, 01:06 PM
  #50
AGMUSA
AGMUSA's Avatar
best engine or best value engine for this class try this
ID:	1905880   Click image for larger version
ID:	1905881   Click image for larger version
ID:	1905882   Click image for larger version
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
