How we build AGM 64 engine
OR
I start this thread to show you how we design and build this engine, we try to combine the advantage of reliable and performance together . talk about the most reliable engine , Zenoah always the first place in my mind . and for the high performance . the rotar valve system is the standard about high performance . so we decided to combine both together . it's AGM64 RR, the first rear carb rotar valve engine (not disk valve engine ) in the market for air plane only .
I hope I can share more info to all of you and enjoy the process with you . as an modeller and designer too .
