Can Spark Plug Ignition Wire Shielding be Repaired or Replaced?
My Feedback: (51)
WA
I have a run away throttle problem with my DA -50 and have finally found the problem (I think). The shielding on the plug wire has frayed completely right where it enters the ignition box.
Can it be repaired or replaced? I can see no way to get into the ignition box as it's completely sealed.
DA wants $140. for their replacement and RCXL only wants $50. for theirs. That's a huge difference. What is the difference?
Money! Get in touch with Adrien at http://www.ch-ignitions.com/ and tell him what you need. You'll get the best service and ignition module from him. Dan.
The DA and RCexl are completely different beast.
DA is timed different than RCexl, DA is timed close to top dead and and RCexl has to be timed between 28-30 degrees before top dead center.
We make a sensor bracket that allows you to use RCexl without having to drill and tap new holes.
http://www.rcextremepower.net/DAIgnitions.html
Milton
Milton
I would remove the plug cap and slip this http://www.mcmaster.com/#5537k26/=ph2bfl over the existing frayed area. Use a small band of heat shrink tubing near the case of the ignition and the free end to seal and make electrical connection. For a few bucks it's worth a try.
The effectiveness will depend to an extent on the type of radio you have. If it's a late model FM or PCM on 72 MHz or a 2.4 GHz Frequency hopper, you should not have any radio issues. If its 27 MHz, or other, it may be a problem even after a perfect mechanical repair.
If not sure you can do a good repair, get a new module or get someone to install a new cable for you.
My Feedback: (19)
This should work okay. A wire braid is, afterall, a simple wire braid surrounding a wire as a shield. You could also add some silicone rubber RTV under the heat shrink and over the braid splice. You don't want wires rubbing. I've done this in an RC truck that came with a 27 band radio and had all kinds of control issues. Once I changed the radio (72MHz FM) and installed an extra shield braid on the cable, I never got another glitch.
With all this said, it sounded like the original braid was broken loose at the ignition box so it would be hard to accomplish a good physical and electrical repair at this end of the cable. If it were mine, I'd just replace the box and there is certainly nothing wrong with the low cost alternative that has been suggested.
I disagree with many opinions of this thread.
I've repaired the metal shield dozens times in DA ignitions and much more in RCEXL and more brands..
See in this forum the way to repair the shield with the kit supplied by RCEXL factory.
(text is in Spanish language but pictures show the method.
http://www.acro3d.com/public/phpbb3/...hp?f=6&t=12140
No one returned with ignition problems.
Best regards
Best regards
My Feedback: (19)
Best regards
Best regards
