removing reed valves
The reed valves allow the air fuel mixture charge to enter on the vacuum part of the stroke and on the pressure part of the stroke block off the charge from going out of the carb.
Basically if you can find a reed valve block that will fit the engine, then it will likely work OK. The reed valves are basically the same for most all of the engines, but they do come in different shapes and sizes. So if you find something that will fit, it will likely work OK.
