EME 70 Twin
Old 08-14-2014, 06:56 AM
irocbsa
My Feedback: (12)
irocbsa's Avatar
Default EME 70 Twin
Does anyone here have any experience with the EME 70 twins?
http://www.milehighrc.com/EME70CC.html
It looks to be a fairly compact engine with at a great price. I love the EME's I already have, especially the ones equipped with auto-start. I'd love to have a twin with autostart but I'd like to hear some feedback before I dump 6 bills on an engine.
Old 03-08-2015, 05:15 PM
Speedy-Gonzales
My Feedback: (202)
I am interested in this engine also and am hoping to see it at TOLEDO in April.
I really wish it was 80cc and am skeptical of the claimed 7 HP rating.
Looking for something other than the heavy burping GT-80 I have now.
Old 03-09-2015, 02:26 PM
tande
My Feedback: (48)
I have the "EME120" & would buy the "70" in a heart/beat, if I were in the market.........FWIW
Old 03-10-2015, 04:18 PM
irocbsa
My Feedback: (12)
irocbsa's Avatar
There's a thread on the other forum that seems to indicate that this is a nice engine. I'll probably pick one up for my giant scale P-47 and report back.
Old 03-12-2015, 04:29 PM
oldtimer4759
hi, I have one, it is in an ESM Corsair, 85in, only about 1 hour air time on it so far, very happy with it, wish I had bought the one with the on board starter, would look cool, runs very nice, not as quiet as I had hoped, quite smooth, would be great in any model with room for a twin, you will need a good starter to turn it over, as both cylinders fire together, I have one of the belt drive HK starters with a 4 cell lipo, only just winds it over,
so far, a very good engine, good power, smooth. Would recommend it.
Oldtimer
Old 03-30-2015, 08:30 AM
irocbsa
My Feedback: (12)
irocbsa's Avatar
I finally scraped up the cash to order one of these. It should be here at the end of the week and will be replacing the Brison 53cc single on my Top Flite giant scale P-47. I'll post back up when I get it running.
Old 03-30-2015, 09:46 AM
dirtybird
I saw a site that advertised buy one get one free
update
The site no longer has engines
Old 05-25-2015, 01:09 PM
irocbsa
My Feedback: (12)
irocbsa's Avatar
Here's an promised update on the EME 70 that I installed in my Top Flite giant scale P-47. Unfortunately, the engine will not fit without trimming the cowl for the plug caps. A lot more would have been required if I used the kit version of the cowl which is a bit thinner than the ARF version. Luckily, I had an ARF cowl as a spare so I trimmed it and painted to match the rest of the plane. The only things that stick out are the muffler pipes and the plug caps. It's not too bad and the added power over the Brison 53 will be much welcomed. At 24.5 lbs it was a bit of a dog with the Brison. The autostart has worked flawlessly. I used the Version 2 motor controller from Mile High RC (essentially a 100A SPDT relay on a circuit board). It was easy to set up but you need to make your own case for it since it doesn't come with one. At $18 thought I didn't mind a little bit of extra work. I need to finish weathering the cowl and she'll be ready to go. I wanted to fly today, but of course the weather in stupid Michigan is always either wind or more wind. Maybe next weekend. If anyone wants a good running Brison 3.2 for a good price just let me know.
Name:	P47 with EME70.JPG
Old 05-31-2015, 11:59 AM
irocbsa
My Feedback: (12)
irocbsa's Avatar
Here's another brief update for anyone interested in this engine. I flew the P-47 twice yesterday before the torrential downpour started. I'm using a 24 X 10 Xoar WW2 prop for break-in and it's turning about 6500 RPM. It pulled the 25lb plane around fairly well but not as well as I had hoped. However, on the second flight it seemed to pick up a few hundred RPM and about 5MPH in the air so I'm hoping it will continue to get stronger as it breaks in. If it continues to pick up power I'll switch to the 24 X 12 that I have waiting in the wings to see if I can get some more straight line speed. On a plane that weighs 18-20 lbs this engine should turn it into a rocket.
Old 06-15-2015, 09:30 PM
oldtimer4759
I have a dozen flights on mine now, very happy with it, I have telemetry gear on my Tx, so I hooked up a Temp sensor to the engine, it is running a bit warmer than I had hoped, about the 140 to 150 C measured at the back of the cylinder head, no signs of running hot in the air or on the ground, just clean exhaust, good to start, I have soldered up the hole in the choke butterfly, I have been running it on 30mls of Oil to 1 ltr of unleaded, I have just mixed up a new batch of fuel, with 35mls of oil in it, see if it makes a difference.
Oldtimer
Old 06-16-2015, 04:54 AM
irocbsa
My Feedback: (12)
irocbsa's Avatar
I've been impressed with the engine thus far. Hopefully it will continue to run well. It seems to be gaining noticeably more power with each flight as it breaks in.
Old 01-29-2016, 02:30 AM
BOLTMAN
BOLTMAN's Avatar
Been a while since any reports here, how are the EME 70s going?
What props are you using after run in & what sort of rpm are you getting?
Old 01-30-2016, 03:33 PM
oldtimer4759
Hi, mine is running great, a 23 x 10 carbon prop, Mez?? At about 7k rpm on the ground, easy to hand flick start, hauls the 15kg Corsair around with out a problem and it is smooth.
Oldtimer
Old 01-30-2016, 05:44 PM
BOLTMAN
BOLTMAN's Avatar
Thanks Oldtimer.
What Corsair are you running the EME in?
I am looking at a Corsair the same size as the Ziroli ( 93" or 2.36m ) and thinking of the EME 70 for that.
When you say the EME hauls your 15kg Corsair with ease, how much more weight do you reckon it would pull and still fly with authority?
Cheers!
Old 02-07-2016, 02:14 AM
oldtimer4759
G'day Boltman,
I have the 85 inch ESM Corsair, the 70cc twin will probably fly the Ziroli, but, we are talking about a War Bird that had horse power, so I would say go for power, the EME 120 or a DLE 110, after all, your Transmitter has a variable throttle and you will probably need the weight.
Oldtimer
Old 02-07-2016, 05:30 AM
BOLTMAN
BOLTMAN's Avatar
Hi Oldtimer,
Thanks for the info. I hear what you say about power, theres nothing like having spare & I definitely know how to use a throttle, but unfortunately the bigger twins you mention won't fit inside the cowl & that is important to me. If I can't have a twin that fits inside I would rather a big single hanging out the bottom. I guess the answer is to build the model nice & light
Cheers!
Old 02-10-2016, 02:45 PM
oldtimer4759
Hi Boltman,
still think your model will need the power, have a look at pictures on this page, it is the same kit as mine with a 110 DLE twin in it, just bits of the plug caps poke out, yours should have a bigger cowl than the 85 in ESM kit. http://www.rcuniverse.com/forum/rc-w...orsair-38.html
Oldtimer.
Old 02-11-2016, 06:28 AM
BOLTMAN
BOLTMAN's Avatar
Hi Oldtimer.
I have a DLE111 and is does not fit. Having plug caps hanging out is not an option as I am building this model for use in competition.
I have flown a Ziroli Corsair powered by a Super Tigre 4500 and the Ziroli was designed around a Zenoah G62. The EME 70 out does either of those for power. I am only looking for scale performance, not a hot rod.
The best option of course would be a Moki 180 but I need to win lotto to get one of those!
Cheers!
Old 11-12-2017, 08:29 AM
redjack
redjack's Avatar
For those of you with the EME 70 w/starter. How are you attaching the wire to the starter? Can you solder it directly?
Gary
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
