DLE 20 fuel consumption
FL
I'm installing a DLE 20 in a Champ with a small tank compartment. I could cram a 12 oz tank in, but it would be a tight fit. A 10 oz tank fits perfect. What kind of run time can I expect? Other than takeoff, all my flying is done at 1/2 to 3/4 throttle, sometimes even less. Thanks for any help.
2 things. First I think a 10oz. tank would be fine for my flying, but it's not going to leave you with a lot of reserve (or extra weight).
2nd, Many/most flying gassers will install the gas tank on the CG, or maybe just in front of it if that's not possible. This minimizes the effect the changing level in the fuel tank has on CG, and there is no down side as the pumps within the carb will pull fuel easily from quite a distance. Is this the area you are considering for your install?
My Feedback: (7)
a 20cc gas engine will consume about .68 oz/minute at full throttle. I use 10 oz tanks for my 20cc powered planes. I think for an aerobatic plane 8 oz would be fine (generally shorter flight duration, at least for me), but I'm too anal to be comfortable with that. 10oz tank gives me a very comfortable reserve.
IL
Last summer I flew a DLE 20 almost exclusively. I flew with a 10oz tank. My flight times were usually 12 to 15 minutes and I landed with several ozs of fuel left. I even had some flights near 20 minutes. Prop was a 16 x 8, fuel 32 to 1 and the plane was a Funtana 125.
FL
thanks for the input guys I have plenty of room in the cabin area to put up to a 16 oz tank and it would be closer to the CG it would be about 11" from the tank to the carb would the engine draw fuel from that far? I may just try the 10 oz tank in its original location and see how it goes thanks
