Is This Safe for Gas??
I need to connect two pieces of tygon tubing. Is this fitting safe for gas? It came with a old Great Planes tank that I used for glow. It's just a hard plastic fitting.
My Feedback: (29)
Personally I would use a single peice of tubing but then again I don't know where in your system this connection is going to go. If it's in the line to the carb I would use a filter, that way there is some benefit to the connection. Maybe a little more info would bring other suggestions.
My Feedback: (48)
MI
If you need gasoline tubing, I carry some of the best. Inexpensive, flexible and durable. Contact me direct only please.
