Da 50 fuel tank
OR
You're probably siphoning some gas out of your vent line. If you fill it until it pours out of the vent and then fly, it will siphon some gas out. You can put an extra loop of fuel tubing in the vent line and this will help. I could show you a video of my Dalton spitting gas out on every downline....and I had a good foot of extra tubing wrapped around my tank. I put in a bit more and this solved the issue.
CB
CB
IL
I'm not sure if I follow, but, if you fill a tank then run an engine. The fuel in the tank is used and air replaces the fuel. The air enters through the vent. I hope this is all we are talking about here.
On the other hand seeing a bubble on the vent line is not a problem. Typically you may see one when the engine is idling which means it isn't drawing much gas. You should not see one (ground runs only) when the engine is at higher throttle positions. When flying and gyrating, the vent in the tank is gyrating also, meaning the vent inside the tank will be submerged and will tend to syphon gas out. A simple loop of gas line around the tank's neck connected to the vent is all it takes to reduce or eliminate the syphoning.
